Thorens motor runs backwards!
Old 16th September 2006, 11:28 AM   #11
I don't think it is a start cap.
I think the synchronous motor is a two phase device that needs the leading phase from the cap connection as well as the standard phase from the direct connection. Then it runs.
But why backwards.
Could the connections into the two phases have been swapped? or would that cause backwards always?
regards Andrew T.
Old 16th September 2006, 01:33 PM   #12
lohk is offline lohk  Europe
lohk's Avatar
if one winding is broken or not connected, I sometimes just twiddles or sometimes run in both directions - by chance. I do not know why, but this happend to two decks already (which I had in repair). Both could only be cured with new motors.
/lohk/
Old 16th September 2006, 01:35 PM   #13
lohk's Avatar
Well, I did not run in reverse - although I must have been funny- but the motors did... (sorry for the typo)
/lohk/
Old 16th September 2006, 01:46 PM   #14
a two phase motor with one phase disconnected will usually not start. If it does start it will run very rough and could go in either direction.
regards Andrew T.
Old 16th September 2006, 08:54 PM   #15
woodturner-fran is offline woodturner-fran  Ireland
sounds to me like the phases are out of alignment with each other. I think I'd go for the phase shift cap first. Its also very cheap fix! If you can't get a .22uF cap, then 2 x .1uF in parallel will do the job nicely.
Its not that big a deal, you can stop the platter and give it a shove in teh right direction and it will run. However, it would be very easy to drop the needle on the platter and not notice it was running in the wrong direction with doom ahead for the cart!
Fran
Old 16th September 2006, 11:46 PM   #16
GhettoSQ is offline GhettoSQ  United States
OK, I looked in the PS box and all I could see was one square yellow cap...should I get the same type?
it doesn't seem to make a difference if I push it.
GhettoSQ
Somewhere between Craft and Kraft
Old 17th September 2006, 12:07 AM   #17
yes, get the same value, type and rating.
Fran
Old 19th September 2006, 04:29 PM   #18
Just to let you know that I did a bit of looking at my ariston rd80sl last night and found that if I switched the motor pos leads around (i.e one goes through the capacitor, one straight from power in) I could make the motor always start in one direct or the other. It might be worth your while to try this too,
Fran
Old 20th September 2006, 05:56 AM   #19
Zene Gillette is offline Zene Gillette  United States
Default Fixed prob accidently
Hi ... My situation is similar. I inavertantly wired my Thorens motor backwards, then the cap went out. Sounds great, now. Zene
Thorens motor runs backwards!Hide this!Advertise here!
Pioneer RT 707 runs backwards bobbus1 Analogue Source 1 28th July 2009 10:09 PM
Still tring to find a couple 100uf motor runs audiobliss Tubes / Valves 16 12th August 2008 10:28 AM
Mounting motor runs jaymanaa Parts 1 30th May 2006 08:23 AM
thorens td 160 replacement motor dionysio Analogue Source 2 31st March 2004 04:45 AM
Thorens TD-160 Replacement Motor dzeetz Analogue Source 9 15th January 2004 08:58 PM
