Need help on  LINN armboard
Old 13th September 2006, 01:08 AM   #1
NickBRN is offline NickBRN  Greece
Default Need help on LINN armboard
I need help on a new LINN arm which I made it...
By plexiglass!
Only one thing left, to open a REGA cut for my RB250
As I know the distance from the spindle to the centre of hole must be 223mm
The arm board 50mm x 300mm.
I wonder where excactly should be the centre of hole , perhaps right in the middle of 50mm side - I mean onto 25mm ?
Any help please!
Old 13th September 2006, 02:45 AM   #2
moray james is offline moray james  Canada
Default Years since I did this...
long time since I set up a tone arm. Mounting the arm directly in the centre of the arm board would be the position where you will get the most amount of structural motion as the distance to all the board edges will be the same. Offsetting the arm on your board will also offset the structural resonances of the arm/board combination. The same thing applies to a speaker on a baffle. Worth thinking about. Regards Moray James.
moray james
Old 13th September 2006, 09:36 PM   #3
Thanks a lot Moray.
Well, I did a mistake about the dimentions of the armboard...
The correct dimentions are 100mm x 280mm, so the middle for the centre of the mounting hole must be on 50mm and not on 25mm as I described before...
But a friend of mine told me that the long side must be 280mm and not 300mm.
Is that correct ?
And what is the distance from the centre of the mounting hole to the back edge of the armboard ?
HELP PLEASE...!!!
Old 13th September 2006, 09:58 PM   #4
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Here is the stock Linn arm location. I used the information that is available on the Vinyl Engine BTW. I will post twice.
Jeff
Old 13th September 2006, 10:04 PM   #5
vinylkid58's Avatar
The basic dimensions given are taken from my stock Linn armboard.
The Rega mounting location was derived from adding 12mm (223-211)
to the Linn hole center @65 degrees. I don't know what the Rega hole size is, I'm sure you can find this or measure the Rega base.
Jeff
Old 13th September 2006, 10:46 PM   #6
Jeff,
I take my hat off...!!!
Thank you so much.
Nick
Old 13th September 2006, 11:40 PM   #7
vinylkid58's Avatar
My pleasure Nick. I may attempt this myself one day. Post a pic when you're done.
Best of luck.
Jeff
Old 20th September 2006, 03:00 PM   #8
Here it is...
Old 20th September 2006, 03:00 PM   #9
Another one....
Old 20th September 2006, 03:00 PM   #10
Another one...
Need help on  LINN armboardHide this!Advertise here!
armboard experimentation YNWOAN Analogue Source 2 4th April 2008 01:18 PM
armboard for TD160 Merijn Analogue Source 5 22nd May 2005 05:40 PM
SME model 10 Armboard cut? ericpeters Analogue Source 0 21st December 2004 04:35 PM
Armboard Materials makinson1 Analogue Source 9 1st September 2004 03:54 PM
DIY sota armboard Gabrielshorn Analogue Source 5 4th December 2002 02:07 AM
Copyright ©1999-2017 diyAudio
