| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I have a problem with my technics, the strobe light flashes on and off when the platter turns and there seems to be less torque. Do you think I should replace q1 (i have 27,27 and 36 volts off Q1)? any help would great Thanks djruntime
#2 |
Hmm...what did the turntable drink?
![]() 35.8V on collector. 21.6V on base 21V on emitter are the correct values. 27V is IMO too high. I never encountered this problem. What happened just before? /Hugo |
#3 |
I think I may have shorted something, was replacing the target light! Just been doing some testing, i think q3 may have blown as i have 15v and 27 volts either side of r2. (also have 15 volts and 36volts either side of r1). what do you think? do you think i may have damaged something else? cheers |
#4 |
What transistor# is Q1? 2SD389 or 2SD1265?
Depending I can post the detail of the PSU with corresponding voltages. Apart from that, you have a good chance Q2 and Q3 are broken. /Hugo |
#5 |
Its 2SD1265
#6 |
Also got 0v at the 5v test point d3, i'm pretty convinced its q2 or q3 now.
#7 |
This might help in case you don't have the schematic.
Go for it, replace Q2, Q3. |
#8 |
Thanks for that, I'm gonna try and get hold of q2 and q3 tomorrow and replace them.
Thanks alot for your help, i'll post my results when they are changed! djruntime
#9 |
Ok its looking better now, i've replaced q3 and q2, but have found that d3 has blown (ma4051mta) any ideas of where i can get these from?? or a suitable replacement?
cheers djruntime
#10 |
It's a standard zener, 5.1V 0.5W.
/Hugo |
| Problem in pitch TECHNICS SL 1210 | Willian Pires | Analogue Source | 4 | 7th February 2008 03:51 PM |
| Technics 1210 Mk5 Problem | qwaszx | Analogue Source | 3 | 31st October 2007 05:19 AM |
| Technics 1210 problem | matt J | Analogue Source | 5 | 19th April 2007 09:25 PM |
| technics 1210 M5G: Has this been rebuilt? | sikniks | Analogue Source | 3 | 1st August 2006 02:04 AM |
| technics 1210 problem | tdiman | Analogue Source | 3 | 25th November 2005 03:50 PM |
| Page generated in 0.09615 seconds (76.55% PHP - 23.45% MySQL) with 11 queries |
