Finished DIY turntable and arm! (pic)
Old 20th November 2006, 07:33 PM   #21
jugi63 is offline jugi63  Finland
Originally posted by Fomob
Very nice looking table. I am curious about the clamp. Where di you source the record clamp or did you make that?
Hi Fomob,
The clamp is made of aluminium, just a wheight - no threads. I bought it from Scheu Analog. http://www.scheu-analog.de/de/index.htm
- jugi
Old 20th November 2006, 07:41 PM   #22
Originally posted by KBK
Try the artist's brand "tri-art" brand 'topcoat'
Hi KBK, Thanks for the tip! I'd like to try it but I don't seem to find Tri-art anywhere here in Finland. Is it just Tri-art topcoat or are there some other similer products?
- jugi
Old 21st November 2006, 03:57 AM   #23
KBK is offline KBK  Canada
Look at what's available in Holland. I think it's available there. I'll check.
edit..too much information. Technical information, that is.
Ok. closest so far, is ATLANTIS artist supplies in the UK.
It's the only one in the market, it is unique. The mix is a cross stressed or cross linked compound, ie, tiny bit of one type of material encapsulated by the resin of the other. Literally a 'water based acrylic urethane' mix. In your house, on a turntable, about a 100 year life span.
So, it's rock hard..and completely flexable. So, it ends up being very, very 'fast'. And your arm will be completely UV resistant.
About a week ago, Steve put some on some paintings. It is still shrinking. The paintings are nearly bulletproof now, and the frames are bending so much, they are going to explode from the pressure, as the resin shrinks. They change note, and the pitch of the drum get's higher and tighter every day. It's crazy.
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 21st November 2006, 10:14 AM   #24
p_ete2003 is offline p_ete2003  Finland
p_ete2003's Avatar
Default the motor
Hi Jugi,
nice tt!
I'm interested in the motor you used. I found the Scheu Analog's site but the price list is on German only. Is the motor you ordered this one:
Kollektorloser Gleichstrommotor, EUR85,-
How much was the total cost for motor + shipping to Finland?
Best regards,
Pete
Old 21st November 2006, 07:18 PM   #25
woodturner-fran is offline woodturner-fran  Ireland
Anyone here using their counterweight/VTA system which I see from the german price list is only from 65!
Fran
Old 23rd November 2006, 01:45 AM   #26
Default Re: the motor
Originally posted by p_ete2003
Hi Jugi,
nice tt!
Best regards,
Pete
Yes, thats it. It comes with the potentiometers and a good ON-OFF-ON switch (they are already wired in also). So you have both 33 & 45 speeds and they can be easly fine tuned. So all you need to do is attach the power supply. A very basic wall mounted DC power supply works ok - although there are differencies in those too.
Have a look at this months Finnish Hifi magazies - there's an artical about mine..
Orders from Scheu a cheap. For the motor probably under 10 euros.
- Jugi
Old 23rd November 2006, 07:03 AM   #27
p_ete2003's Avatar
Jugi, thank you for your reply!
Did you consider any other motors before ordering this one? I think I'll read the article in a library
Br,
Pete
Old 24th November 2006, 06:21 PM   #28
Br,
Pete
Well, not really. I have quite a big trust for Scheu's stuff. People with some very expensive equitment seem to like Scheu TT's - and motors.
Maxon was a motor manufature I looked at a bit, but rekoned that the Scheu motor is at least as good. Can't say since I've no experience with Maxon, but as I happens there came a info paper with the Scheu motor where he (Mr. Thomas Scheu has passed away already) compares is motor to the "famous" Maxon and concludes his is better and more simple to run evenly.
The soundscapehifi.com/eurolab.htm -site has some nice info about Scheu (and others) and some it is trancelated in Finnish at: http://www.musiikin.com/scheu-page.htm
- jugi
Old 25th November 2006, 08:14 AM   #29
p_ete2003's Avatar
Hi Jugi,
thank you for the reply! I'll check the link later..
Br,
Pete
Finished DIY turntable and arm! (pic)Hide this!Advertise here!
Just finished first amp nkg Tubes / Valves 14 6th October 2007 11:17 PM
New Sub Finished! greg_mcquaid Subwoofers 5 25th April 2007 02:47 AM
just finished BIB TL's weikertball Full Range 5 2nd August 2006 02:11 PM
Here's my finished DIY (yet another one...) ChesterFuzzin' Multi-Way 2 22nd April 2003 06:02 PM
Just finished TLs Thatch_Ear Multi-Way 2 2nd December 2002 01:13 AM
Copyright ©1999-2017 diyAudio
