| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi all
I am inviting opinions. My phono pre (Electrocompaniet) uses current amplification. I messed a little with the input load resistor value (10R) onlly to go back to the original value of 10R. I used a fresh commercial grade metal film resistor. The sound just seemed wrong. Replaced with the original "used" resistors and a all was well. So what is your favourite load resistor type: Vishay Bulk MF? Tantalum? Precision Carbon? Any number of Metal Films from Holco, PRP etc? I guess experience with passive I/V CD stage resistor types would count here as well. Ta |
#3 |
Hi SY,
Is there that much of a difference? Naked foil or bare (I'm guessing sealed / coated)? There can be differences in metal film types that are measurable. -Chris |
#4 |
The ones I have are sealed in little square epoxy packages. I'm not sure of the brand- got 'em as a gift.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
Sy,
You're one lucky fella. Good going! ![]() One fella was recommending the naked bulk metal foil over the encapsulated ones because "he could hear a difference". Physiology is a wonderful thing. They cost more he says, that must be it! That's like having a naked capacitor! Okay, low voltage. -Chris |
#6 |
if a wire (non inductive wound) resistor were made, what material should sound best? Copper, constantan, nichrome? Others?
regards Andrew T. |
#7 |
For a virtual earth current amplifier the best load resistor is none at all ! /sreten.
#8 |
Hi sreten,
Can't argue that, except you still need a sensing element. That would be doped silicon in most cases (ultimately). -Chris |
#9 |
To be accurate the cartridge internal resistance becomes the "load" resistor and the virtual earth current stages voltage gain becomes directly dependant on the cartridges impedance, self adjusting. Adding a 10R series "load" resitor simply makes the gain changes less severe as the cartridge source resistance changes, whether this is a good idea or not depends on the internal gain setting. /sreten.
#10 |
I think the 10R sit from signal in to ground, that is parallel not series?
| Which resistor type for emitter resistor? | sajti | Parts | 25 | 8th April 2009 06:12 AM |
| Driver stage load resistor | Klimon | Tubes / Valves | 3 | 18th October 2006 09:26 AM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| Plate load for 6SN7 gain stage? | G | Tubes / Valves | 53 | 16th July 2003 10:07 AM |
| Page generated in 0.09806 seconds (81.38% PHP - 18.62% MySQL) with 10 queries |
