Thorens... Thorens... - Page 2 - diyAudio
Thorens...
Thorens...
Old 19th January 2003, 09:18 AM   #11
Raka is offline Raka  Europe
Raka's Avatar
Default Yes, an AC maker seems to be fine
I'm doing this thing (I'm very slow and lazy ) and someday I will finish it. It's well explained in another thread I opened, search for the "Change in the frequency mains" one.
Seems to be an easy project and someone reported good results.
I wouldn't try to put mass in the platter. The Inertia would be higher, but if a perfect calibration can't be achieved the medicine is worse than the illness.
To fit a DC motor with voltage controls doesn't seem bad. Iím going to search for a kit from some electronic supplier.
What is beyond the speaker?
Old 4th May 2007, 12:34 AM   #12
makinson1 is offline makinson1  United States
makinson1's Avatar
I thought the adjustment on the springs was for ride height, that it did not change the spring rate.
Old 4th May 2007, 02:45 PM   #13
hurdy_gurdyman is offline hurdy_gurdyman  United States
hurdy_gurdyman's Avatar
The looser the springs are adjusted, the longer the bounce time, as it lowers the resonant frequency. Tighter makes shorter rate bounces. I'm not sure why this is, but it seems to be, at least it did with mine. Not a big difference, but noticeable.
I re-read what I wrote earlier and need to make a correction. The springs shouldn't be tight enough to make the sub-chassis actually touch chassis. If floor bounce is a problem, though, I've found that having them as stiff as possible helped in my room. I never did eliminate the problem, though, and ended up selling both my TD-145 and TD-160. I bought a suspensionless table and made a high mass plinth. Foot-fall problems are gone now.
Dave
The only thing I like better than the sound of a banjo is the sound of a cat having a shampoo in a flushing toilet!
Old 4th May 2007, 03:09 PM   #14
Default Td150
Mak is right.
The bottom of the springs sit on the washers and in turn on the adjusting nuts. The tops of the spring support the rubber washer and that supports thearms of the cruciform that holds the spindle bearing.
The cruciform/bearing/platter float on the springs.
Adjusting the nuts just moves the platter up and down and when incorrectly set tilts it as well.
Correct adjustment eliminates the tilt and this may give a better bounce. It should not adjust the frequency.
However, the sponges inserted in the springs may change the damping immediately after an adjustment and this temporary condition could lead to an apparently changed bounce. As the sponges settle into their new positions the original damping and frequency will return.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th May 2007, 03:33 PM   #15
That may be what it was. The foam was rotted on mine, so I replaced it with some that was in there tight. Never thought of the foam catching on the bolt threads and making a difference, but I can see where it would. Thanks for clearing it up. Makes sense now.
Perhaps one can fine tune the suspension by how much and how tight the foam is?
Dave
Old 4th May 2007, 08:14 PM   #16
makinson1's Avatar
I rechecked the service manual (available for free download at VinylEngine.com) and it reads "the plastic gizmos raise and lower the chassis. Interestingly emough it shows an optional (disco balls) device to replace the springs in high vibration environments that look like little tennis balls or black rubber balls. So we are back to the beginning: put the TT on a stout stand, level the stand. Adjust the Thorens srews to level the plinth. Hope for the best. Many people, myself included, believe that the foam spring inserts are rubbish. I even tried filling mine with scraps of sorbothane. Probably did more harm than good by raising the fundamental frequency above 3Hz. Would love th know the stock Thorens spring rates. I used to have a contraption that had a scale on the bottom with a platform for the spring, an arbor press type lever to compress the spring, and a dial indicator on top to mesure deflection or amount of compression. So you would pull down on the arm a little, the scale would read 1.25 lbs, the dial indicator would read 0.25in, so we knew by simple division that that spring was 5lbs/inch. mayve if I put my digital phono stylus gauge in the bottom of my rifle cartridge reloading press, inserted the Thorens spring, taped my 6" machinists rule to the side, pulled down on the arm, read the scales and did the math, I would know the Thorens Spring Rate. Actually this would be darn accurate. I could see which springs had gone soft after 35 years of use. Thene I could buy a variety of springs from McMaster-Carr and Small Parts Inc to play with and fine hone the suspension. Sorry for the verbose reply, but sometimes waxing prolix clarifies the muddied waters of discourse. This maters to me personally because I need springs for my new DIY TT Thorens clone: see attached jpg.
Old 5th May 2007, 07:37 AM   #17
The springs will not have gone soft.
The material and the size has not changed over the years.
It is possible but very unlikely that they may have shortened very slightly. If they have shortened this can be corrected in the levelling process
regards Andrew T.
Old 30th May 2007, 04:58 AM   #18
Alfredz is offline Alfredz  Australia
Default Thorens TD 125 Mk II motor
Does anyone know where I can get a replacement motor or get it rewound? I am in Australia.
regards,
Alfredz
Old 30th May 2007, 12:56 PM   #19
makinson1's Avatar
Expect to pay $60 USD if you find one on eBay.
Thorens...Hide this!Advertise here!
Thorens 166 d to the g Swap Meet 0 23rd May 2007 01:31 AM
Att Thorens 126 Mk 2 retrodisko Swap Meet 0 17th November 2006 07:04 AM
EMT 928 (& Thorens 125) snoopyma Analogue Source 1 5th January 2006 01:56 AM
thorens 160 psu stueyh Analogue Source 11 6th June 2005 11:02 AM
Thorens TD-319 FaZ72 Analogue Source 24 15th May 2004 11:59 AM
Copyright ©1999-2017 diyAudio
