Old 30th June 2006, 10:12 AM   #1
Default changing MC cart loading
Hi all,
Does anybody know what the correct way to do this? I want to use the MC output part of my phono stage (NADpp2) for a denon cart which should be loaded with 1.5K or so. Can I just open up the box and solder in the appropriate resistor across the RCA jacks, i.e. 1.5k resistor from centre pin to outer? Will this do it?
Or should it be with the resistor in series, between the pos centre pin and lead from it?
Fran
Old 30th June 2006, 11:06 AM   #2
The PP2 input MC loading is 100 ohms + 100pF.
Assuming the input stage uses series feedback you need to find
this input loading resistor and change it to 1.5Kohm both channels.
/sreten.
Possible constructionfailure with Grado cart? Triumph Analogue Source 4 11th March 2007 05:42 PM
cart help kjunom Analogue Source 9 23rd April 2006 11:31 PM
Linn Arm with Ortofon Cart JodithPWorld Analogue Source 4 10th March 2006 05:01 AM
Anode Loading Vs. Cathode Loading ? valveitude Tubes / Valves 19 22nd July 2005 10:00 PM
Cart align gary f Analogue Source 4 18th June 2005 03:09 PM
Page generated in 0.05914 seconds (67.59% PHP - 32.41% MySQL) with 10 queries
