Sansui TU-S33 problem : need you to check - Page 2 - diyAudio
Old 30th June 2006, 05:31 PM   #11
Malefoda's Avatar
Send a message via MSN to Malefoda
Ok guys, I've taken the dead parts (yes a C1815 is dead also...) in my old radio CB Midland... nad it works fine! (I've even found it works better ).
Thanks for your support, I'll go on changing parts as psu caps for better ones (if left from my CD53 upgrade...) and still ask if any reward if I change the main cord and wire the ground?
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Old 30th June 2006, 07:42 PM   #12
Malefoda's Avatar
And also, I have to choose between 220V our 240V, but in France it's... 230! What may I choose? Any idea for the light of the front panel? Someone with the component to built the noise filter?
Old 18th December 2006, 12:45 PM   #13
Malefoda's Avatar
Small upgrade with spare parts from my CD53 upgrade:
power supply section get new and better
If this can help...
Old 15th March 2007, 12:02 PM   #14
Malefoda's Avatar
Bypassed output caps: bad idea, a big noise when switch from nosignal to locked signal. Will put MKS2 1uf in place of the 0.33uf/100V electrolytics.
Old 15th March 2007, 09:57 PM   #15
Malefoda's Avatar
Talking Final touch (if any end...)
So, I've removed the wires wich bypassed the output caps (C44R/L), changed from OEM 0.33F/100V to Wima MKS2 1F/50V, changed C42R/L, C36, C23 (not sure) from 1F/50V to 1F/50V Elna RJH, C38 from 470F/16V to 470F/25V RJH, and changed the strange NEC IC cap (under the PCB between two pins) from an old 1F/50V to the left 1F/50V RJH.
PSU upgard also, C5 from 470/16 to 1000/16 and C6 from 100/16 to 220/16 ZL Rubycon. Maybe will go for bigger 25V rated ones if any caps left.
Former PSU upgrade in previous posts.
No more " ploc " ( DC...) when mute/unmute with signal. Even less DC offset than before! The sound definitly improved a lot, much balanced than before. At least it pleases me, which is the point. =)
If this may help anyone one day...
Old 9th May 2007, 07:23 PM   #16
Malefoda's Avatar
Default Re: Final touch (if any end...)
Hi there again:
I finally foind the sound a bit diffrent, is it the MKS Wima at C44L/R that are bad here? My I find some gain goin' MKT or even MKP?
They were 0.33F electrolytic, they are for DC offset. Any advice for removing my Wima 1F MKS? I've in hand some 0.22 MKS4, but still MKS... some 2.2F MKT or 3.3nF MKP. The value should be 0.33F I guess... please your though about this.
If any of the ones I've in hand can be better than the MKS it's a free upgrade for me!
Thanks!
Old 23rd May 2007, 08:37 PM   #17
Malefoda's Avatar
Got 0.22F MKP, but rated X2. Still better than MKS?
Old 29th May 2007, 07:18 PM   #18
Malefoda's Avatar
MKP rated X2
Will try MP3 ( Wima's not music!!) 0.33f Click the image to open in full size.
Capacity does match and maybe the MP3 sounds better then MKS...
Old 30th May 2007, 06:08 PM   #19
Malefoda's Avatar
Will not, MKS 0.47F instead.
Old 6th May 2008, 09:50 AM   #20
Malefoda's Avatar
I'm fitting cheap Audyn-Cap 0.33F in, will tell you (were 0.47 63V Wimas... instead of OEM 0.33 'lytics).
There are some muting transistors at the output, how can I remove it, just remove? How does it work, I've to by pass some left open path there?
Q7R & Q7L and paired R?
Matthieu
Sansui A-60 problem gecko Solid State 3 17th December 2010 06:04 PM
sansui R70 maxpou Solid State 2 1st November 2009 11:21 PM
Sansui xr q9 nik75 Digital Source 0 14th June 2009 11:12 PM
Sansui decap problem? Taiga Chip Amps 7 2nd August 2008 09:27 AM
Sansui AU-111 stonehome Swap Meet 1 14th June 2006 03:37 PM
Copyright 1999-2017 diyAudio
