What's a good test signal to match two decks' azimuth with?
Old 16th June 2006, 10:27 PM   #1
damianm is offline damianm  Argentina
Default What's a good test signal to match two decks' azimuth with?
Hi everyone
I've been using a cassette deck again for the past few months and would like to play my tapes in a couple portables I've got.
I was wondering what a good test signal is, something that will make it real easy to set azimuth by ear using just a tape with that signal and a screwdriver, as I've got no other equipment.
I find that I'm not particularly sensitive to small variations in steady tones, otherwise I'd just use a 10 kHz tone from a test tape. I've also tried using music with lots of HF content but I can never be sure if I've nailed it.
Thanks!
Old 16th June 2006, 10:35 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
10Khz is fine. If you have a scope you can adjust a little bit better but I recall setting azimuth on average decks by ear with good result.
/Hugo
Old 18th June 2006, 01:20 AM   #3
Ghianni is offline Ghianni  Greece
Make a record of white noise (-20dB) then playback this noise on portables and adjust their azimuth by ear for the "sharpest" noise.
Ghianni.
Old 18th June 2006, 12:07 PM   #4
R.I.P.
as suggested interstation noise from your fm tuner is probably best.
/sreten.
Old 18th June 2006, 03:00 PM   #5
Yes that's it. FM interstation noise is like white noise.
Ghianni
What's a good test signal to match two decks' azimuth with?Hide this!Advertise here!
Tape decks for recording bands on, what's a good one? Test Electrix Analogue Source 3 15th April 2009 05:59 PM
Intermodulation test signal BitPoint Digital Line Level 5 6th April 2009 12:06 PM
Jitter test signal - 11025+229.6875hz. How to ? percy Digital Source 5 25th April 2007 01:13 AM
Best Digital (bit perfect) Test Signal? drewm1980 Digital Source 3 23rd May 2005 01:09 AM
Good Match? Mnipl Car Audio 3 6th June 2003 01:17 PM
