Old 11th June 2006, 11:14 AM   #1
wrenchone's Avatar
Default SME3009 II with Kenwood KD500
I have some old SME 3009 II tone arms. I'm thinking of mating one to a Kenwood KD500 TT. Worth doing? Is the bronze bearing upgrade for the SME tonearm worthwhile? Is this tonearm considered to be a low mass arm? I have a Grado Gold and an original Sumiko Blue Point. which would be a more appropriate combination with the SME arm? Is there a rule of thumb fro compliance vs. effective mass?
Old 11th June 2006, 11:44 AM   #2
phn is offline phn  Sweden
phn's Avatar
I cannot see why not, though I personally think the tonearm is the most overrated component on a turntable. It's medium mass, by today's standard. Analogue Classics.
The bronze bearing, as you know, gets favorable reviews. But I think only you can decide if the price tag is justified. Yours at least has a steel bearing and not the plastic one found on some later models. The Sumiko looks like a perfect match.
Old 11th June 2006, 11:49 PM   #3
wrenchone's Avatar
Actually, I misspoke. It's the 3009R I have with the nylon bearing, so I think I would want to change that out.
Old 12th June 2006, 12:05 AM   #4
phn's Avatar
Might not be a bad buy. After all, you have everything else. Aren't we all grasping for that brass ring?
Old 12th June 2006, 12:14 AM   #5
wrenchone's Avatar
I'll probably try one of the arms as is before I spring for the new bearing. However, I have to keep in mind that the arms (3 of them) have been jumbled around in a box for a while, and the plastic bearings may have suffered. They were discards from the college radio station where I DJ. Between the 3 arms, I have enough bits and bobs to get at least one working.
Old 12th June 2006, 09:06 AM   #6
phn's Avatar
That's how I would do it.
Old 12th June 2006, 10:02 AM   #7
The Grado Gold is more likely to sound well with the SME than the Blue Point IMO.
/sreten.
Old 12th June 2006, 02:53 PM   #8
phn's Avatar
The recommended tracking force of the Grado (of which I have no experience) is 15 mN and 18 for the Sumiko. I can be wrong, but I doubt there could be much improvement either way. On the other hand, why argue? Test and see which you prefer.
Old 19th June 2006, 11:21 AM   #9
Nam402 is offline Nam402  United Kingdom
I also have an SME 3009 arm (mk11 improved fixed headhshell). I've had conflicting advice on a suitable cartridge and I'm now muddled.
Is this arm too light for a MC cartridge and if so which MM to go for?
Hope I'm not hijacking this thread, just have the same kind of problem!
Cheers, Nam402
Old 19th June 2006, 01:35 PM   #10
phn's Avatar
Nam402, you can use pretty much any MC cart that works with the modern SME and Rega arms. You have to look for a high-compliant cart, under 15 mN. The problem is that they tend to be expensive. At least I know of no cheap one. Hopefully somebody that uses high-compliant carts can recommend something.
As for MM, Goldring should do. Of course, so will Ortofon, Shure, and any other MM cart. I like Goldring. But I'm not the kind of guy that recommends on thing over another. Only you can decide what suits you best.
Kenwood KW-44 hum DaveWM Tubes / Valves 2 26th April 2009 10:19 PM
Sell or Swap Thorens TD-165 & Kenwood KD500 turntables (B.C.) (and other stuff) dangus Swap Meet 11 22nd October 2007 04:40 AM
kenwood 923 mike49504 Car Audio 5 20th October 2006 12:13 PM
MC cartridge for an SME3009 SII marcanto Analogue Source 2 16th September 2005 05:21 PM
SME3009 Arm wrenchone Analogue Source 2 3rd June 2004 12:25 PM
Page generated in 0.09988 seconds (77.73% PHP - 22.27% MySQL) with 10 queries
