SME3009 II with Kenwood KD500
Old 19th June 2006, 01:55 PM   #11
audio-kraut is offline audio-kraut  Canada
I have run the arm w/o problem with ortofon MC 3, Shure V15VxMR and the Denon DL 160.
Gives you a range from 80 to 350$.
Old 20th June 2006, 07:02 AM   #12
R.I.P.
Originally posted by Nam402
I also have an SME 3009 arm (mk11 improved fixed headhshell).
I've had conflicting advice on a suitable cartridge and I'm now muddled.
Is this arm too light for a MC cartridge and if so which MM to go for?
Hope I'm not hijacking this thread, just have the same kind of problem!
Cheers, Nam402
just more MMs to add to your list :
The Audio Technica AT120E/T is the cheapest out
there (AFAIK) fitted with a quality nude elliptical tip.
The Audio Technica AT440MLa is the cheapest square
nude extended contact tip out there, tip lasts ~ twice
as long as the above.
Both would be execellent buys for the SME if they
suit your system - they are brighter than most.
If you need a duller sound then The Grado Green is an option.
The Ortofon 520 or 530 are very neutral and work very well.
The Goldring equivalents 1006 and 1012GX would also work
well, if you've a knackered cartridge lying around you can
get a very good discount on these at mantra-audio.co.uk.
/sreten.
Old 20th June 2006, 07:25 AM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Back when i was selling KD500s new, i installed a few 3009s on them.
Myself, i'd take the box of pieces and sell the parts on eBay -- should fetch enuff to buy a really nice arm
dave
planet10/ has owned at least a dozen 3009s and a one 3012.
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th June 2006, 07:26 AM   #14
Nam402 is offline Nam402  United Kingdom
Thanks folks,
This is really helpful advice.
Cheers, Nam
Old 20th June 2006, 07:46 AM   #15
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Well, I don't doubt that there's better arms out there than the 3009, just as there's lots better turntables than the KD500. However, the tonearm I have will work lots better than that elusive perfect tonearm I don't have, especially as the 3009s were free. If I opened the floor to questions about what that perfect arm might be, I'd get N+1 violently differing opinions, (N being a large integer) and I'd be no better off than I am now. I'll use what I've got, maybe fix it up a bit. If I don't like the sound, then I'll sell it.
BTW, what I've got is three more or less intact arms, the only loose bits being the anti-skating weights. If I do anything with the other arms, maybe I'd sell one of them and get a high output Denon MC cartridge., which may sound better than the old original Blue Point I've got.
Old 20th June 2006, 08:21 AM   #16
Onvinyl is offline Onvinyl
Onvinyl's Avatar
Hi wrenchone,
before you use rules of thumb for soundwise best matching of cart/arm, you need to know which resonance frequency that combination has. This should be less than 12Hz.
Take
Fres = 1000 / 2*phi* srqt( M*C)
where M is Mass of cart + effective mass of the arm, and C is the dynamic compliance of the cart. The effective mass is not the simply the weight, but is given in the user manual or on several places on the net. Be careful, as there are quite a few different versions of those arms around. Some are light (the 3009 III-series and the ones with fixed headshell), most others are on the heavy side and perform quite well with the famous DL103, for instance.
You then need to reassure the resonance F. with a test record, because the carts compliance may differ significantly from the nominal value and you can't be sure that your arm is indeed the one you have the data for.
The brass blades are worthwhile if you don't have steel bearings, but check first if the arm meets your requirements as those 3009'es are indeed overrated, at least some incarnations. But they perform well on subchassis players, otoh.
HTH,
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 20th June 2006, 07:38 PM   #17
wrenchone's Avatar
I have the Hi-Fi News test record, which includes a tonearm resonance test band. I's amusing to play it and watch the speaker cones suck in and out. My current system resonates at a bit below 10 Hz - maybe about 8 Hz. It also breaks up very obviously at resonance. I'm currently using a Kenwood KD-2055 with the Grado Gold.
For the last time, I know there are better tonearms out there, but it's not like I went out and spent hundreds of dollars on my 3009s - they were free. All I want to know is how to best use what I've got.
It's going to be interesting figuring out how to estimate effective arm mass, as I'll be using a non-standard carbon fiber head shell. It sounds like I can backtrack by measuring the resonant frequency of the arm-stylus system using a cartridge of known compliance and use that info to calculate effective mass. It's a very simple matter to put a frequecy counter or a scope at the output terminals of my amp to measure the exact resonant frequency.
Old 20th June 2006, 07:59 PM   #18
frugal-phile(tm)
planet10's Avatar
My point was that people pay ridiculous money for these -- even in pieces. I got something like $120 for one with a multilated headshell, no cable, no antiskate and who knows what bearing condition. That is ~half-way to an RB250 (at least the last time we got one). With 3 mostly whole ones....
dave
Old 21st June 2006, 03:11 PM   #19
Onvinyl's Avatar
Wrenchone,
i'm not telling you to throw your arms away but to check if you can live with the arm sonically before investing in expensive upgrades.
And yes, you can back-calculate from the measured resonance-freq (if all bearings are in at least fair working condition and the arm is set up correctly, of course).
Rüdiger
SME3009 II with Kenwood KD500Hide this!Advertise here!
Kenwood KW-44 hum DaveWM Tubes / Valves 2 26th April 2009 10:19 PM
Sell or Swap Thorens TD-165 & Kenwood KD500 turntables (B.C.) (and other stuff) dangus Swap Meet 11 22nd October 2007 04:40 AM
kenwood 923 mike49504 Car Audio 5 20th October 2006 12:13 PM
MC cartridge for an SME3009 SII marcanto Analogue Source 2 16th September 2005 05:21 PM
SME3009 Arm wrenchone Analogue Source 2 3rd June 2004 12:25 PM
