| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#111 |
Hi Kiraly,
Back in the early 1980s I was given a Larsholt FM module. I had it hooked up to a digital display and it worked very well. Unfortunately I cannot now find it ( I was a kid then!) and I would like to replace it. It had the following features: Switchable IF sensitivity - I believe 3 choices but may have been 2 Switchable MPX filter On / Off Switchable AFC On / Off one aerial input Output for digital frequency display I think it may have been a LH7254 but I cannot be sure. I would be grateful if you could help me and I would be interested in the kits you have, especially if any of them use the module I had. I look forward to hearing from you. Best wishes Peter Newbury, UK |
#112 | |
As the FM Bands are the same, it should work in Europe. It will not receive DAB, of course.
If you do not want to use a step down transformer, you may need to replace the internal mains transformer, or rig up an external power supply to replace the internal power supply. The FM de-emphasis can be corrected by an external circuit. Do a google search on this tuner and you will find these mods. Your search will also find users in the UK. Quote:
#113 | |
I believe that Sony's software code is what gives this tuner its spectacular performance. Another maker's implementation of the chip set may well give inferior results.
#114 | |
PS:- If my two examples are typical, this tuner's AM performance is nothing to get excited about. Find yourself an old Lowe HF-150/225 series radio, or a modern Palstar, to listen to for good quality AM reception.
#115 |
Hi all,
I listen to the radio a lot, so I'm thinking of building a little FM mono tuner + amp + speaker for my working room. The idea is to build a small box with the tuner + amp with only two knobs for volume and tuning. I'm searching a small tuner that can be paired with a small amp like this one: small amp on ebay Any ideas where to find such a tuner? A frequency display would be great but not necessary, only a knob for tuning is required. Advice on amps are also welcome. TIA, Ralf |
#116 | |
For a more ambitious tuner, go for the Silicon Labs chips like the SI47XX series. The 4704 and 4731 are more complex, but the SI4731 comes with a complete demo board with an LCD requency indicator and AM loopstick antenna, etc. Not sure of the cost of the demo board, but it's a damn decent digital FM tuner chip (no programming needed for the demo). If you're not afraid of getting dirty with some digital, any of the PIC micros can talk to the Silicon Labs chip as well as another, possibly the simplest, FM tuner chip in existance. The Philips TEA5880. This is a complete FM stereo tuner that needs exactly 2 external components, L1 and L2, both 0.38nH inductors that can be simple spirals of PCB tracks. SMT inductors can also be used. The PIC (or any suitable microcontroller that can emulate a simple 3 wire serial port) can set the frequency of operation and generate a readout, get the stereo pilot and so forth. This is another low IF based FM tuner like the TDA7000 series, but one heck of a lot better performance. You can add a buffer front end as shown in the TDA7000 series app notes using an untuned inductor and a BC849 transistor (any suitable VHF transistor). Most of the parts can be had from Digikey or Mouser or Future Electronics. The USLs for Philips and Silicon Labs. NXP Semiconductors Silicon Labs - leader in high-performance, analog-intensive, mixed-signal ICs. |
#117 |
I am afraid that your information given above is not quite up to date.
Firstly none of the parts mentioned above are on stock at DK or Mouser (only listed), except for the SI4731 Demo Modules at around 60 USD. The TDA chips were originally Philips, but since they became NXP, they sold that business to ST, and ST has put most of the TDA70xx stuff obsolete. There are only a handful of dealer who still have stock. The SI chips are all one chip tuner, which means they use varicaps and caps integrated in the IC. I have build one of these with a JFET analog output stage : Mini-Stereo-RDS-Radio-Modul Fertiggert, bernsteinfarben | ELV-Elektronik It is again all digital with lots of features, but the sound was so-so even with a discrete output stage. Then I built one using the TDA7021/7040 according to datasheet / Elektor : Mini VHF FM Receiver - ELEKTOR.com | Electronics: Microcontrollers Embedded Audio Digital Analogue Test Measurement but replace all SMD ceramic caps with MKP or mica, and also added an opamp amplified output stage. It sounds fantastic for the cost and the simplicity. The key is the choice of discrete components. I will build a JLH FM next year, but that is a LOT more effort than this. Just my own personal experience, Patrick Last edited by EUVL; 10th July 2010 at 06:31 AM. |
#118 |
I see you have a few surface mount components on there. Presumably you could have used ordinary bits instead? I've not done much hand soldering of surface mount but I know it's not easy.
#119 | |
Quality varies per sample as to how much treble you're going to get, as it varies between slightly insufficient or far too much. The unit is designed, like most electronics of today, as a short-life easy-bake oven so that you'll have to buy something else in a few years, when it commits suicide due to heat. An external power supply may be a consideration, since the included power supply is inefficient, causing additional heat. A quickie fix for heat is to put on some of the extra tall rubber feet and enlarge the plastic vent holes by cutting out every other plastic louver, making half as many vent holes at much larger size. Speeding up the airflow that way does just happen to work decently. What you get for your $100 is one the best RF sections made, teamed up with a lot of junk that needs fixed. The AF section is very bad quality. Its not just noticeable, its execrable. Documentation on exactly how to do the necessary upgrades is pretty scarce due to lack of photos that show exactly where to connect what. So, the many projects with this tuner are indecipherable except for people who are already capable of building their own tuners. Ironic. The scan, tune, features on the unit and its remote are somewhat inappropriate until you set up the presets. The presets work great, but for one appalling exception. The memory lasts only a couple of minutes during a power outage, so this thing forgets all that work you just put in to get it set. So, this also needs an upgrade. As a bonus, it has the "blinking zeros" clock that runs, with a light up panel, even when the unit is off. And yes, that needs fixed too. When a station has a borderline signal strength between digital or analog, the Sony HD will merrily bounce back and forth, and when that's going on, it doesn't make a useful audio presentation. Its possible to upgrade this behavior with a mechanical switch installed somewhere, which could lock the tuner to analog. And, the point. . . Well, a plain old superhet, if given a rather elegant booster with filtering and a slightly more substantial antenna, is going to perform a lot better for Audio, with no significant increase of difficulty. In the case of the Sony, there's an excellent RF section and the rest needs an overhaul--a whole slew of band-aid fixes upon miniature circuits. However, in the case of the handmade tuner, the RF section is some effort but audio quality may be easier. Or, a better point. . . Since its hard to purchase a table radio with an excellent speaker and AF section, a handmade project with either handmade tuner or a tuner-board product, plus some excellent DIY audio, can make a presentation exactly as desired by its owner. This isn't available in stores. |
#120 |
Its different, and drifts a little bit. But it lacks the nice things like digital tuning. But its great for a fixed tuned receiver.
Never used them, but I heard the ZN414, 416 make a good AM receiver. They're TRF tuners which eliminates the bandwith restriction of IF stages. Would probably sound pretty good on a strong signal. |
| Larsholt fm tuner front end for JLH tuner design-Any still available? | djsb | Analogue Source | 0 | 25th December 2008 05:46 PM |
| DIY your FM Tuner | 3moons | Analogue Source | 0 | 23rd November 2003 12:09 PM |
| For tuner.. | Sch3mat1c | Analogue Source | 11 | 14th February 2003 07:45 AM |
| diy pcb, tv tuner ? | gabdab | Parts | 0 | 3rd January 2003 04:48 PM |
| Page generated in 0.15962 seconds (84.67% PHP - 15.33% MySQL) with 11 queries |
