Old 4th June 2006, 06:27 PM   #1
Default repair chrome plating
I acquired an sme 3009 at a decent price - below 100$ - which had parts missing.
Parts are there now, but the armtube was a bit scracthed up.
Tried to polish using 000 steelwool and # 800 and 1000 sandpaper and brasso.
Most of the scratches are gone now, but where the severer ones were I worked down to the original metal.
Is it advisable to repair using a small chromeplating kit like this one:
http://www.caswellcanada.ca/products...7&gosearch.y=8
and do I have to take the old plating right off or can I just plate over it?
Thanks for any help in advance.
Old 6th June 2006, 01:05 AM   #2
phn is offline phn  Sweden
phn's Avatar
Since nobody has answered and you probably want to have the tonearm fixed and up and running...
My advice is to ask a company that does these things.
Old 6th June 2006, 01:15 AM   #3
Hi phn,
the arm is aluminum, and therefore anodized - as I found out.
I removed the old anodizing, polished the arm (after removing the wiring and the cartridge plug in) and will send it now to an anodizing shop here in canada (alberta).
Sending it to SME would have involved major layout of non budget funds. Just check what SME charges for an rca converter kit - over 100 pound sterling. Same thing from germany - 33 euros.
Thanks anyway for the reply.
Old 6th June 2006, 01:37 AM   #4
phn's Avatar
I'm a bit puzzled here. Isn't that a high-gloss wand? Anodized aluminum is rather dull. I can be wrong, but I think it's lacquered alu.
Old 6th June 2006, 01:46 AM   #5
You are right, it is high gloss, but it was definetely some layer on top of
the original aluminum - took quite some time to remove it.
I am down to the original aluminum now, and have it polished just nicely.
I am considering just applying urethane lacquer (spray).
Had done this to a labelled frontplate and it lasted forever - even scratch resistant.
Old 10th June 2006, 07:39 PM   #6
bulgin is offline bulgin  South Africa
Default Repair chrome plating
Hi audiokraut
That SME arm is polished, lacquered aluminium - no anodising, like phn said. I have a 3012 with a very minor mark left by the armrest clip.
Anyway, imho you should have started cleaning with 3M waterpaper (wet or dry) at about 600grit, them move to 800, 1000 and 1200grit. Then, if there is a hobby or craft shop near you, get some Japanese-made Tamiya finishing abrasives. These come in small cellophane packs with grit grades from 1200 to 2000.
Be sure to get only 3M waterpapers for the coarser work. I found some other brands for some reason or other, embed grit into the job while sanding.
The last step would be to use a fine polishing paste. Mine comes in a little blue plastic box and is sold also by hobby shops or by agents for Proxxon tools. This stuff is superb and will give your arm a mirror finish.
bulgin
Old 10th June 2006, 07:44 PM   #7
poobah is offline poobah  United States
poobah's Avatar
Toothpaste will make a nice DIY polishing compound... cheap, and I'll bet you have some (well I hope so).
Old 10th June 2006, 07:55 PM   #8
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
My SME3009/S2 was very definitely chrome-plated aluminium. The previous owner managed to damage it when he tried to fit an ADC magnesium headshell. (He apparently gripped the arm tube with a pair of serrated edge pliers then twisted the tube so that it graunched. Hooligan.)
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th June 2006, 08:03 PM   #9
poobah's Avatar
I had a guy do that to 80 backshells for military connectors ($40 apiece) because he thought wrapping some rubber around them first (as was demonstrated to him) was too much work. FIRED!
Old 13th June 2006, 03:26 AM   #10
auplater's Avatar
Default cleanup of aluminum arm
You might consider a buffing wheel and either tripoli or white rouge, using a soft fabric 6" wheel and a fairly light touch, you should be able to buff out ALL scratches to a mirror bright finish... then a quick wipe with alcohol or MEK to remove waxes and spray lacquer will be MUCh cheaper and look as good or better than chrome plate... a not so trivial job on aluminum anyway.
auplater
chrome corrosion/pitting... from what? elementx Instruments and Amps 3 7th December 2006 10:06 AM
Chrome chassis Prune Parts 2 18th June 2004 03:49 AM
Sylvania Chrome top 6SN7 tube Original Burnedfingers Tubes / Valves 15 27th December 2003 03:20 PM
OT: Aluminum chrome plating? thylantyr Solid State 7 24th August 2002 06:46 PM
Chrome Heat Sinks more_power Solid State 23 31st May 2002 08:04 PM
Page generated in 0.11419 seconds (78.27% PHP - 21.73% MySQL) with 10 queries
