Rega Motor connection circuit
Thanks,
I'll try , but on ebay I've seen a resistorin serie with the capacitor and also a circui with two caps and two resistors.
If a pair are on the power on there is everytime a resistor more.
Ciao
Guglielmo
The cct I put in the thread is what I took from my notes on my own Rega Planar 3 some years ago (220 V 50 Hz).
Your first Pic you posted I recognise as being the 110 60 Hz connection. Beware, if you use the motor in the pic the pulley more then likely smaller then 220 V 50 Hz version and even if wired for 220 V it will run slow. Freq, not volts control AC motor speed... Hence the different pulleys for 50 and 60 Hz.
This may be the reason it is for sale? ;)
Not sure about the other 2 pics. I guarantee my cct will work on 220 v. Speed is dependant on pulley being correct for your countries frequency.
