Old 22nd May 2006, 03:21 PM   #1
Default thorens 160
Hello,
I am having an issue with my Thorens 160 (TP-16 arm). I am currently running a AT110E cartridge and it sounds ok on most records however...when I am playing a brand new record I keep getting excessive distortion of vocals when they become loud. This also occurs on jazz albums with loud brass playing.
What would this be related to?
Could it be the stylus? Or could the cartridge be a bust?
Could anyone who has a great cartridge on their Thorens 160 (TP-16 arm) let me know what it is.
Thanks!
Old 22nd May 2006, 03:27 PM   #2
dnsey is offline dnsey  United Kingdom
What's the downforce set at?
Old 23rd May 2006, 07:50 AM   #3
could it be a bias problem?
Does it sound worse on one channel?
Have you got and used a test record?
regards Andrew T.
Old 23rd May 2006, 10:30 AM   #4
Bobken is offline Bobken  United Kingdom
The obvious 'common denominator' in your comments if I understand this correctly here, seems to be that this problem only occurs when the *recording* is "loud", as you put it. i.e. "loud vocals" and "loud brass".
I assume this is not the same as when you are playing all music 'loudly', but merely when there are heavily modulated (or 'loud') passages actually on the recordings.
If this assumption is correct, this would immediately suggest to me that there is some overloading somewhere in the chain, and most probably at the pre-amp's input. The output of this cartridge could be a bit high for the pre-amp's input capability, and this could be checked out by reducing the level by way of a simple resistive attenuator between the cartridge and pre-amp.
Ready-made plug-in RCA attenuators are commercially available (at least in the UK) and if there are no other problems at any time when playing records which might suggest a cartridge fault/excessive stylus wear, I would try out this reduction in signal from your cartridge as a first step.
If the problem is due to mistracking on heavily modulated passages, this should improve with slightly higher tracking forces, so it would be worth trying this first.
Bob
Old 24th May 2006, 04:27 PM   #5
Default Fixed - thanks for the help!
Thanks for the help all,
I check the VTF - aka increased it...with no change in the distortion.
Realigned the cartridge and such with no result.
Then I decided to take a walk to my local hi fi audio shop. Talk to a few people and they thought as I...the cartridge/stylus was the problem - probably degraded or worn out.
I ended up purchasing a new cartridge...and voila...sonic bliss. The cartridge i got was a Nagaoka MP-11 (new stock)...and does this thing match up well with the TP-16 arm! I am astounded with the improvement in sound....I find it to be much more musical than my old AT110E.
Anyway, thanks for your advice and happy spinning.
Old 24th May 2006, 07:06 PM   #6
pred is offline pred  Switzerland
Hi I recently acquired on thorens td 160 and have a question,
I would like to align the cartrige but never did it. Found a lot of info on the net but I seem not to be able to understand how I can move the cartridge in the thorens headshell. So I wanted to ask is it posible (the arm is original tp16 I guess) to move it and how. And if there is a "pictured" procedure somwhere on the net? I never turned my thorens upside down (I will have to do it soon to install beter chinch connectors and power cord) so I am not really sure how it is done.
Thanks in advance,
Pred
PS
I have test record and protactor and now how to proceed after (in theory at least )
Old 24th May 2006, 08:20 PM   #7
Netlist is offline Netlist  Belgium
Netlist's Avatar
I believe the TP16 headshell has fixed set screws.
Only the VTA can be adjusted.
Here's a nice page on the subject.
/Hugo
Old 24th May 2006, 11:33 PM   #8
Default Headshell adjustment
If you look at the headshell with the cartridge not attached the metal piece the screws for the cartridge attach to is free floating and with a bit of pressure will move forwards or back. Also, lateral adjustment so the cartridge is square can be achieved by leaving the screws untightened (a little bit) and ajusting with a little twist o the cartridge....make sure to not touch the stylus (it is easy to hit it and ruin the cartridge) - when finished adjusting tighten up the screws
I suggest using a protractor to assist with alignment.
Take a look at the Analog Depot online....a great resource it has a whole section about TD 160's.
Good luck.
Old 25th May 2006, 01:33 AM   #9
infinia is offline infinia  United States
infinia's Avatar
Hi
From you description, most probably worn or damaged stylus. What is the history of the cartridge i.e. high hours and/or known abuse? Been there before myself with a second hand Grado. I kept adjusting alignment not wanting to believe what I feared.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 25th May 2006, 10:26 AM   #10
Default Re: Headshell adjustment
Originally posted by thorens309
If you look at the headshell with the cartridge not attached the metal piece the screws for the cartridge attach to is free floating and with a bit of pressure will move forwards or back...
Thanks a lot I will try it as soon as I find some spare time. While we are at it any good cartridge for thorens bellow 200$ mark. I have MM phono preamp (my design).
Pred
Thorens 166 d to the g Swap Meet 0 23rd May 2007 01:31 AM
Att Thorens 126 Mk 2 retrodisko Swap Meet 0 17th November 2006 07:04 AM
EMT 928 (& Thorens 125) snoopyma Analogue Source 1 5th January 2006 01:56 AM
thorens 160 psu stueyh Analogue Source 11 6th June 2005 11:02 AM
Thorens TD-319 FaZ72 Analogue Source 24 15th May 2004 11:59 AM
Page generated in 0.11502 seconds (79.55% PHP - 20.45% MySQL) with 10 queries
