Old 25th November 2002, 07:29 PM   #1
Merijn is offline Merijn  Netherlands
Default armboard for TD160
Hi
I need a template to make a new armboard for a SME 3009/ TD160 combo. The TD160 came with a TP16-1 arm, but the headshell is about 3 degrees out of line with the armtube. Now I think of refit the Thorens with a SME 3009, but therefore I need to make a new armboard. Any suggestions?
Old 25th November 2002, 11:05 PM   #2
wuffwaff's Avatar
Hello Merijn,
I made one out of perspex for my TD150. The only important thing is that you get the distance from arm pivoting point to middle of the turntable right.
Normally there´s a template with the 3009.
I still have one for the 3009 II so if you need the distance I can measure it for you.
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 18th December 2002, 12:27 PM   #3
Thank's a lot, but finding a not too expensive SME with not too much wearing is hard. actually I have not been able to find one for less than 350 euros/dollar... Maybe I just take another arm like Rega or Pro-Ject...
Old 30th December 2002, 09:54 AM   #4
Raka is offline Raka  Europe
Raka's Avatar
Default Rega arm
I'm also thinking about fitting a rega in my TD160. I was thinking also in Pro-ject but is only 12% cheaper than the RB300
I have an RPM4 from project, so I can comment about the project9 tonearm: When I fitted the cartridge I went to a pro (a friend of Linn) to set it up and he only growled about the low quality. He was true, the bearings were lazy as me. Instead of floating like an astronaut, the arm stayed where it was left (not so exaggerated, but obvious) . I complained at the shop where I bought it and they changed the arm. Now it was agile, but the antiskating device is not the best and it has slightly a trend to go outside. I tested it with a test lp and it tracks well (until track number 3) I think that with a better skating will get better tracking.
Well, it's better than the thorens arm, but I suspect that the RB300 is much better. Does anyone else have any comments?
Does anyone have fitted a rega in a thorens? any difficulties building the armboard?
What is beyond the speaker?
Old 19th March 2003, 01:36 PM   #5
Raka's Avatar
Default Distance
I finally bought the Rega 250 for my td160, with the OL VTA adjuster. Unfortunately, I've discovered that the rega needs 222mm from spindle center to arm pivot center, i.e. more than the TP16. Actually, the thorens arm is 215 approx. away. Is this a problem?
The OL instructions states a 3mm safety margin, not enough
Has anyone fitted a rega in a thorens?
Old 22nd May 2005, 05:40 PM   #6
Doctor Zoidberg's Avatar
hello Merijn, I think this could help
http://www.theanalogdept.com/sme_td160.htm
http://www.theanalogdept.com/images/...Echematic1.jpg
Please dont credit me... the Analogue Dept site is The Place if you need info about Thorens tables...
See you
Zoidy
armboard experimentation YNWOAN Analogue Source 2 4th April 2008 01:18 PM
Need help on LINN armboard NickBRN Analogue Source 21 15th July 2007 09:20 AM
SME model 10 Armboard cut? ericpeters Analogue Source 0 21st December 2004 04:35 PM
Armboard Materials makinson1 Analogue Source 9 1st September 2004 03:54 PM
DIY sota armboard Gabrielshorn Analogue Source 5 4th December 2002 02:07 AM
Page generated in 0.09441 seconds (77.01% PHP - 22.99% MySQL) with 11 queries
