| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi All
I have just acquired this NOS "Toshiba OPTI" cartridge, which I have been led to believe may be an interesting type in that it used a modulated light beam and photodiode to translate stylus movement into electrical signals. Does anyone have any info on it, specifically as regards the electrical connections & pinouts? |
#2 |
First of all I must say that I know nothing about electronics and technical stuff. I'm only a old LP record fan that like to play his favorite tunes on old hardware (amp and turntables). If this info can help you, I am pretty sure that your cartridge is designed for the Toshiba Opti TR-50 turntable. I think you should try to get info about the TR-50. I was unable to fing good infos on the web yet. If you can find some, I would be interested. I wonder where you got your cartrige from ? I just bought a TR-50 without original cartridge so I'm looking for one. If you want to sell it... Regards, Anar |
#3 |
What I have learned about this cartridge is that it requires a special preamplifier, with non-RIAA equalisation, as well as an uncommon input configuration.
The cartridge contains two photodiodes, so does not generate any voltage as do ceramic or magnetic cartridges. Instead, the generator acts as a variable current source, and as such needs an excitation potential. Further, the cartridge requires 2V at 200mA or so to illuminate the phototransistors. |
#4 |
The cartridge will be an amplitude transducer rather than a velocity transducer (magnetic cartridges), so a perfect transducer would only require a shelf equaliser with time constants of 318us and 75us.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#5 |
You will be happy to find this bit of info on the Toshiba cartridge.
http://www.badenhausen.com/VSR1Pickups.htm /Hugo |
#6 |
Hi Moderator netlist
Thanks for the interesting and educational link you posted regarding diyaudio member steerpike's query re this cart. Will it be OK if I draw our friends at VE's attention to your post? Regards bulgin |
| Empire 2004 cartridge info | percy | Analogue Source | 5 | 9th October 2011 10:10 PM |
| Shure cartridge info. and differences. | tubewade | Analogue Source | 3 | 29th August 2007 04:28 AM |
| Found Some 2SC367 Metal Can Toshiba Transistors...Any Info or uses for them | Minion | Solid State | 5 | 2nd April 2007 08:30 PM |
| Info on Decca cartridge loading sought. | Aleksunder | Analogue Source | 6 | 30th November 2006 12:52 AM |
| Toshiba XR-Z90 - Any info? | Duncan | Digital Source | 0 | 15th August 2005 04:24 PM |
| Page generated in 0.08430 seconds (75.72% PHP - 24.28% MySQL) with 11 queries |
