| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#51 |
Just a couple of things;
Nice work by many there :-) I've never had any problem achieving a good finish on Delrin - a slightly radiused cutter (rather than a point) makes it a lot easier though (as does exactly the right speed and feed). I have also used the method used by Bob P. to mount items in the lathe - always worked well. My experience of cast acrylic is also that it thickness across sheet varies significantly and all surfaces must be machined true. |
#52 |
Hi, I managed to mess up the drilling of my cutting board 2" wooden platter.
An idea i had while searching eBay for circular 300mm diameter objects was to use disk brakes, they can be bought for around £30+/-. They must be machined to high tolerances.? I have tried to find out if they are they magnetic and whether this will affect the MM my cartridge? I remember reading someone wanting to try it, but can't find the link or site it was one. So anyone thought about it, or have any brain waves.
#53 |
Have you never seen a rusty disk brake?
#54 |
So steel, and so magnetic?
Its not gonna be spinning round at 80mph in all weathers. Just at 45rpm |
#55 |
They are magnetic...
hoping to pick up some things. |
#56 |
Does that entirely rule them out?
Can you demagnetize? Would it still affect the stylus in there was an inch acrylic platter on top? |
#57 |
I don't see what it would. That is actually a pretty interesting idea. You would need to damp the heck out of it to tame the natural ringing of steel. But talk about a cheap way to make a high mass platter.
#58 |
| Foamies - as a platter mat | Moke | Analogue Source | 2 | 8th August 2008 01:47 PM |
| the perfect platter | graeme uk | Analogue Source | 8 | 28th February 2007 08:12 AM |
| Platter | hifido | Analogue Source | 0 | 6th November 2006 08:17 PM |
| Idea for a DIY platter | Zero One | Analogue Source | 1 | 22nd May 2006 06:28 AM |
| Platter material | A3rd.Zero | Analogue Source | 15 | 6th May 2004 03:07 PM |
| Page generated in 0.12582 seconds (67.52% PHP - 32.48% MySQL) with 11 queries |
