| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Just built this new base for my Technics sl1300. Want to put feet or some sort of isolation something or other on it. Any suggestions? I know, I have to get it off the stand that it is on. That things rings like a string.
#2 |
try squash balls cut in half. These are hollow rubber balls.
Also, you could cut two matching sheets of board and in between them glue a bicycle inner tube. You can then inflate this to whatever psi is necessary. Good luck |
#3 |
Another variation on the squash balls in to use them complete. In this case you fit retaining rings to the plinth, a simple tube. Then choose your speed of squash ball, I think yellow spot. /sreten.
#4 |
I have used squash balls for over 2 years. I did not monitor regulary, but noticed just a month ago that my table (sandfilled) was tilting.
The squash balls (yellow dot) detoriate unevenly. They are still laying on my workbench, first the dimension was eliptical ball Dmax Now I am using a tube, not glued, fixed between to rims. By the way I only use this construction because of WAF. I have to keep my deck in a kind of cupboard, when not in operation out of sight. When WAF is not a problem I would first experiment with rigid construction and different top platters, wood, MDF, reinforced glass, marble etc. and some spike type of things. It is my feeling/experience that it is more important to get the "energy" out of the turntable/deck then the otherway around. In my case the cupboard construction urged me to do it also the otherway around. For what it is worth regards, E&E |
#5 |
Thanks guys! I have started using a bike innertube and all traces of sound and vibration are gone, not only in playback, but when I put my ear on the plinth and bang on the table that the turntable is sitting on! Man the bike innertube idea is fantastic. I am drawing up plans to build a platform that will hold the innertube and allow the valve to come out the side with teh tube in an evenly distributed labyrinth like shape. I will post plans sometime in the future.
#6 |
Awesome! With your great results I will build one of these ASAP!
#7 |
Have been using bike inner tubes for some time now to support my modified Thorens TD 125 and they certainly work.
The only thing I have found with them is that tend to go flat over time and need reinflaiting - this even happens with the thick 'thorn proof' ones that are used by mountain bikers. I suspect that the valves could be the cause?? I intend to seal mine when I get round to spring clean my system. Mike |
#8 |
Here is a variation on the inner tube design:
http://www.audio-ideas.com/reviews/a...-tweaks-3.html Also has the valves accessible from the exterior of the box as Harderror suggests. |
#9 | |
I made some myself, from 2 component silicone which hardens till a soft rubber is left. I molded them in contact lens disposable packages, they had a half sphere cup. The rubber is used to make a mould of an ear Concha for hearing aids! (am now educated for hearing specialist) The rubber works fine but is a little slippery, the speaker which i provided the stands can be shifted easily from its place. Maybe the rubber has to be grinded a little with sandpaper.
Daisy Bell |
| Feet? | phreeky82 | Subwoofers | 6 | 27th August 2007 11:27 PM |
| Feet or no feet? | mazeroth | Subwoofers | 8 | 17th December 2004 05:55 AM |
| Looking for cones (feet) | ftjandra | Parts | 7 | 4th August 2004 05:03 AM |
| 40' (yes, that is feet!) TL!!! | jag | Multi-Way | 4 | 22nd February 2003 02:50 AM |
| feet for downfiring sub | jtriggs | Multi-Way | 5 | 20th February 2003 12:18 AM |
| Page generated in 0.10237 seconds (75.67% PHP - 24.33% MySQL) with 11 queries |
