Old 12th April 2008, 10:07 PM   #21
paoloop is offline paoloop  Belgium
Default Hydraulic tonearm
As for the comparison with Thorens 125 and SME 3, the problem is not with Transcriptors but with its SME2 arm (and possibly the base); I have the same combination, but my Transcriptor has the original fluid arm: I have no influence at all from loudspeakers! So I ended doing the opposite: Transcriptors main, Thorens 125 reserve.
Moreover the Fluid arm is an unipivot, and that adds dynamics and 'air' (at least that's my impression). I'd like to know from 'Transcriptors' member why did he change to another type of arm in the new production (an Origin live if I'm correct).
I know it had bad reviews, but I have to repeat: at least with some medium compliance cartridges it shines!
Old 27th May 2009, 07:22 AM   #22
Send a message via MSN to ronenash
Hi all,
I just got a Hydraulic Reference and started doing some restoration work on it. Replaced the silicon fluid in the platter assembly, installed new platter weight pads and a new belt.
I am getting some noise coming from the barring. I still have not had a chance to trace the source but it might be that the motor is not fully floating on its springs and is touching the chasis in some way. One thing I did notice is that the speed control does not work. Although the small pin in immeresed in the silicon fluid it does not change the speed. I can see some speed change when I move the speed control lever but after a few seconds it continues to run a bit fast. Not sure if anyone else has seend this.
Sound wise its a very decent table that compares quiet well with my Thorens TD125.
Ronen
ronenash
Old 27th May 2009, 02:14 PM   #23
Default Hydraulic speed control
I had the same speed control problem at the beginning: in my experience it has two possible causes:
a) the belt doesn't go around the stroboscope...
b) the pin lever is not well fixed: I put a little rubber underneath the pin arm, and then it did work fine
SME 3009-s2 on my transcriptors hydraulic reference? spookybonus Analogue Source 2 19th March 2005 08:56 PM
Tonearm Question : Transcriptors Magnetmaz Analogue Source 1 15th October 2004 10:25 PM
Transcriptors Saturn turntable for sale + vestigial + shure V15 Magnetmaz Swap Meet 6 29th July 2004 04:07 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
