Old 23rd April 2006, 10:32 PM   #1
PTSOUNDLAB's Avatar
Default Thorens TD150 replacement motor
Hello,
I restore an old Thorens TD150 and need a new motor (16 pole, 2-phase synchronous AC motor). I think to take off the pulley on the old and put it on a new one.
I think of these motors :
Premotec http://rswww.com/cgi-bin/bv/initSess...tockNo=4410423
Linn LP12
All are 250rpm 50Hz.
Somebody know if these motors are OK for TD150 ?
Pascal
Old 23rd April 2006, 11:29 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I think you'll find it's a 24 pole motor. Any 24 pole synchronous motor will rotate at 250rpm when driven by 50Hz. 24 pole motors were very popular for turntables. If you measure the pulley diameter and the subplatter diameter, divide the one into the other, then multiply the result by 33.33r you should be able to check whether your existing motor is 24 pole (I think you'll find it is). After that, your only problem is whether the shaft diameter is correct for your pulley.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th April 2006, 10:27 PM   #3
PTSOUNDLAB's Avatar
Hello EC8010,
thank you.
My pulley : 14mm (for 33tr)
My subplatter : 160mm
The shaft diameter 3mm
I think that this Airpax motor http://fr.farnell.com/jsp/endecaSear...U=147876&N=401 could be the good one for my TD150
Best Regards
Pascal
Old 25th April 2006, 08:53 AM   #4
EC8010's Avatar
Well, doing the sums from your measurements says that the motor rotates at 377rpm. That means that you were right and I was wrong because you do need a 16 pole motor that rotates at 375rpm, but the Airpax motor says 250rpm because it's a 24 pole motor. I assume you've tried asking Thorens about a replacement motor? The other possibility is to drive the Airpax motor from a 75Hz supply. A 75Hz oscillator and a little loudspeaker amplifier driving a step-up transformer would do the trick.
Old 26th April 2006, 10:15 AM   #5
your Thorens 150 motor only needs 90Vac to 110Vac to drive the platter.
Hopefully your replacement motor will not need any more voltage.
It would be even better if it needed less voltage, possibly no step up transformer.
regards Andrew T.
Old 13th May 2006, 09:38 PM   #6
Alain Dupont's Avatar
Pascal,
I have the original motor from my TD 145, it was setup in 220 Volts 50 Hz
but here in Canada it didn't work...
If you want it ; with the pulley.. ? give me a message!
I did replace it with a origin live DC motor 2 years ago.
Regards.
Alain
Old 8th October 2006, 01:46 PM   #7
Alain, are you still keeping the 220v50Hz motor.
I would like to get it for the replacement of my 117v60Hz TD160 motor. If you can send it to me, please tell me the cost and how can I pay to you.
Regards,CHOW
Old 8th October 2006, 02:28 PM   #8
audio3chung,
Yes, I still have it, little use because during about 15 years the TT has been stored
you only need to apply some oil ; and it's the original motor of my TD145 with pulley
Could you give me your postal address, please
so I can check for shipping cost
I have a paypall account. I sell it for the shipping cost...
my email: aldupon AT sympatico . ca
remove the spaces and replace the AT by @
Regards.
Alain.
Thorens TD150 Mk1 Arm part needed waam68 Analogue Source 9 29th January 2008 07:03 AM
thorens td150 turntable peter hawthorne Analogue Source 2 4th November 2007 10:56 PM
Thorens td150 & SME 3009 cougarnut Analogue Source 4 18th October 2006 08:27 AM
thorens td 160 replacement motor dionysio Analogue Source 2 31st March 2004 04:45 AM
Thorens TD-160 Replacement Motor dzeetz Analogue Source 9 15th January 2004 08:58 PM
Page generated in 0.11289 seconds (75.58% PHP - 24.42% MySQL) with 11 queries
