| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
hey guys,
i've been toying around with a couple phono stage simulations and i've been looking for a calculator that can help me churn out component values for the eq network. be it a composite on or a split one. has anyone see any around? thanks a million!!! |
#2 |
try some of these for background & info. http://www.diyaudio.com/forums/attac...amp=1139076552 http://www.diyaudio.com/forums/attac...amp=1139341846 http://www.diyaudio.com/forums/attac...amp=1140854548 Will the correct Doug Self Wireless World RIAA please stand up?
regards Andrew T. |
#3 |
hey! thanks a million!!
#4 |
the Harms' excel sheet is much easier to use than the optimal, since optimal is designed specifically for ultra low error and to show the results. I have posted my version with slightly tweaked values to see just how low the errors could be made and what error is permissible with component selection. Resistor accuracy will require a good DMM, but required cap accuracy is beyond my test equipment. But the display will let me see what errors will result from component spread.
regards Andrew T. |
#5 |
#6 |
Hi all,
I'm doing adjust my RIAA circuit in my pre tube phono. my circuit is like in this http://www.mh-audio.nl/CalculateRIAA.asp. with standard components based on that link was showed, I feel not satisfied on the bass. So I need a software or some can estimate the result in chart. Could any one help me ? thanks a lot. |
#7 | |
(For perfect RIAA equalisation, the output will be the same level for each frequency between 20 and 20KHz, using a reverse RIAA board.) BTW, the passive composite RIAA network you linked to, lacks Allen Wright's "50KHz pole". This is an additional resistor R3.18 in series with C2. This paper gives the equations to calculate the values: SJS Electroacoustics Home Page - Makers of Arcadia Valve Amplifiers (Click on "Read it" and then "Phono Stage Design & Schematics".) Regards, Andy |
#8 | |
| BSC Calculator | hongrn | Multi-Way | 5 | 10th December 2005 05:06 PM |
| is this the simplest box calculator on the net ? | zuki | Subwoofers | 6 | 18th February 2005 05:37 PM |
| Vdd calculator (which thread)? | djdamix | Solid State | 2 | 15th February 2005 12:51 PM |
| here's my new OB calculator :) | hitsware | Full Range | 11 | 12th November 2004 03:42 PM |
| DRD calculator | garbage | Tubes / Valves | 2 | 29th October 2004 02:31 PM |
| Page generated in 0.12313 seconds (71.70% PHP - 28.30% MySQL) with 11 queries |
