"Vintage" JVC Cassette Deck; metal bias?
Old 12th April 2006, 04:49 PM   #11
kevinkr's Avatar
I had a KD-85 I bought new in 1977 for a great many years, unfortunately my ex got it when we split up back in 1999 - at that point it was still running just fine. Incidentally I liked this deck a lot better than the two Revox B-200 that replaced it.
I can understand why you would want to fix yours, and I wish you good luck.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 12th April 2006, 07:07 PM   #12
Sir Trefor is offline Sir Trefor  United States
Sir Trefor's Avatar
Exclamation Transport removed
I am in the process of servicing the transport; I have completely removed it from the unit.
No need to fear; I have meticulously written down every process, part, and screw removed along the way. I have numbered all of the parts and screws in my writings, and have cross-referenced those numbers with pictures I have taken along the way. I am positive I will be able to put it back together properly.
Thanks for the help and information, Klaus!
-Trevor
"This is just my 'one cent'; I haven't got two to give."
Old 12th April 2006, 07:12 PM   #13
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Default Re: Transport removed
I'd love to see one of these exploded views.
/Hugo
Old 17th April 2006, 02:34 AM   #14
Sir Trefor's Avatar
Default Re: Re: Transport removed
/Hugo
When I have a really good one of all the parts all over my bedroom floor!
Klaus, would your repairman be able to help me if I provide you with photos and dimensions of all the rubber parts in the transport?
Thanks, all
-Trevor
Old 11th May 2006, 06:07 AM   #15
Sir Trefor's Avatar
Default It is time to revive this thread
/Hugo
I must revive my thread by holding up to my end of the bargain-
Here is tranport partially out-
Now, with the "umbellical cord" cut, and from the front-
From behind, with the flywheel and capstan assembly removed-
Old 21st December 2009, 11:46 PM   #16
tbearcooper is offline tbearcooper  United States
Yup, got your problem nailed. Had a KD-55 for a long time. When they shipped new the motors were no good. Yours just took a little while to fail. Since you say wasn't used much I assume it has few hours on it. Mine failed one week after getting it. JVC replaced the motors under the original warranty with a transistor controlled one. After that played fine for 10 years before it failed again.
"Vintage" JVC Cassette Deck; metal bias?Hide this!Advertise here!
vintage JVC cassette deck godsound08 Everything Else 1 14th May 2008 06:41 AM
crate vintage "club 50" schematics needed cbriere Instruments and Amps 2 14th November 2007 06:39 PM
4 Sale: Vintage JBL L40 Adjustable Crossover "Pair" (2 way) Minion Swap Meet 3 22nd January 2007 05:41 PM
