| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I MAKE PCB FOR RIAA BUT I HAVE NOISE. SOMEBODY HAVE A PCB FOR THIS PHONO OR HOW I PLACED RCA GROUND AND PS GROUND. THANK'S
#3 |
I HAVE A HAMMOND TOROIDAL TRANSFORMER 44V CENTER TAP 160VA, 4 CAP 4700UF NICHICON FW DECOUPLING 0.01 POLYESTER METAL BY CHANNEL. PHILIPS AND 2 REGULATORS 7824 VISHAY ONE FOR EACH CHANNEL. THANK YOU!
#4 |
Maxpou,
Please turn off the Caps-lock. I'm sure it's not your intention but this style is considered as shouting. As for the PSU, a schematic would be handy as well. /Hugo
#5 |
Electrons are yellow and more is better!
7824 regulator might be too noisy, just a hunch. How much decoupling do you have after the regulators?
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
i have 4 caps 4700uf decoupling with 0.01 by caps by regulator. thank you!!
#7 |
This circuit has a low first stage gain followed by the RIAA network attenation so it won't be that quiet. As Peranders has said, it is also very sensitive to supply noise.
#8 |
which circuit you propose for power supply?
#9 |
Try batteries with as much bypass capacitance you can afford. Apart from PSU, this is a forgiving circuit: it was my first project a while ago since 15 years or so and it worked quiet good. Rüdiger |
#10 |
you can use this "cleanup" circuit from Wenzel Associates -- the entire article can be found on their website. Just make sure that the opamp you use can take the voltage. (i.e. you don't want to use one of those low power, low voltage ones.)
Paralleling more 2sk170's on the front end will reduce "device" noise further (at the expense of more current consumption). http://www.wenzel.com/documents/finesse.html
| JFET SRPP RIAA Preamp | wrenchone | Analogue Source | 178 | 14th May 2012 06:45 PM |
| Hello from the Pacific NW! | Brian44 | Introductions | 4 | 7th May 2008 08:12 PM |
| All JFET open-loop RIAA pre-amp | Mr Evil | Analogue Source | 29 | 12th April 2005 02:26 PM |
| RIAA Pacific deluxe from Elektor | peranders | Analogue Source | 4 | 26th February 2004 03:52 PM |
| Source for Pacific Microsonics | Eargasm | Digital Source | 9 | 6th November 2002 01:36 AM |
| Page generated in 0.10822 seconds (75.79% PHP - 24.21% MySQL) with 11 queries |
