Old 16th November 2002, 11:06 AM   #1
Shoog's Avatar
Default Tubes for a MF X10D
I have an MF X10D between my pre and power amp and one of the tubes has gone down(I have had it for about 6 years). Despite searching the net I cannot find the spec on the tubes used and they arent maked.
Anyone know where I might be able to source them in Europe. I read somewhere that a useful improvement could be made to its sound if audio spec tubes are used instead of military spec. Any comments?
Old 16th November 2002, 01:38 PM   #2
diyAudio Senior Member
fdegrove's Avatar
Default X10D
The X10D uses a ECC88/6DJ8 per channel.
You could use the professional equivalents instead but I can not predict any sonic improvement if any:
E188CC/7308 or E88CC/6922/Cca are equivalent with the sole difference for the E188CC being very low noise.
Ask your supplier for a matched low noise pair of valves,that would at the very least reduce residual noise.
I'm not aware of Irish valve vendors but there must be some around.
In the U.K. there are quite a number of them:
CVC
This is just one I traded with in the past.
Happy trails,
Frank
Old 17th November 2002, 08:54 AM   #3
Shoog's Avatar
Default Thanks for that Info.
Turns out that the problem lay with our cat eating one of my cables. However that link and information is very useful.
musical fidelity x10d schematic arvin Tubes / Valves 61 24th April 2013 07:04 AM
Musical Fidelity x10d schematics here JDowland Digital Source 9 29th March 2013 05:02 AM
Using a Musical Fidelity X10D as a Valve Buffer. Shoog Chip Amps 1 24th March 2013 03:37 PM
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
