Old 25th March 2006, 02:15 PM   #11
Eggzy is offline Eggzy  United Kingdom
Default who needs counterbalances?
I wonder whether this is worth a go...
Old 26th March 2006, 01:08 PM   #12
nghiep is offline nghiep  United States
The V shaped counterweight mounting increased the arm effective mass considerably. If one moved the V shaped counterweight mounting aft of the pivot, one would decrease the effective mass and use the counterweight as an lateral balancer also. One can also tune the unipivot arm by the arm effectivemass because the amount of friction and the pivot interfacing materials at the pivot affect the sound. One can also counterweight the arm by a ballon with a lighter am effective mass also. Counterweight located aft of pivotal point is a good thing in tonearm.
Old 31st March 2006, 04:40 PM   #13
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
A friend of mine had a similar idea and floated a ball in goo as a before-pivot counterweight. I told him at the time it would have even more effective mass than the SME weight he was replacing... (Quite apart from what it did to the restoring force of the knife-edges.)
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 31st March 2006, 05:02 PM   #14
baggins is offline baggins  United Kingdom
baggins's Avatar
Just been reading this thread -- Nice arm
It occured to me to ask my usual silly noob question :-
If one could theoretically hang a cartridge from a proverbial sky hook would the mass of the cartridge body alone be sufficient to enable the stylus to track large excursions? and if not how does one calculate the minimum rotational inertia an arm should have?
heretics are sometimes right
Old 2nd April 2006, 08:49 PM   #15
wmincy is offline wmincy  Malaysia
nghiep, thanks for your suggestion. You and my father had the same idea, and soon i'll bring on with a new one.
In these days we put the tonearm in testing, to assist its performance.
We tried with 3 cartridges, all are low compliance type: Sumiko Bluepoint, Micro Benz Silver and Grado Sonata Wood. The first two, high output, sounded with deep powerful bass and many details (playing with Wham! 45 rpm), Micro Benz prevailed in bass responce, Sumiko Bluepoint was more in sustain. Both are high quality cartridge! Superb sound! In term of cost/performance.
Today we tried the Grado. New in the box, haven't run in. It sounded slower, warmer, more "analog" and digged more information. Hearing Carol Kidds, her voice was sweet and involved the entire atmosphere. Pavarroti's voice never fatigued.
the fever of DIY HI-FI will NEVER be cured !!!!
Old 2nd April 2006, 10:40 PM   #16
rfj5106 is offline rfj5106  United States
Default My unipivot tonearm
Wonderful arm. Can you post some more dimensions on the V shaped component?
Richard Jenkins
Old 3rd April 2006, 12:09 AM   #17
Hi, wmincy
I think all three cartridges have medium compliances. I also think your design providing more stabilization than aft pivot counterweight. Your counterweight controls lateral movements between the cartridge and pivot rather than aft of pivot point. The normal formula for tonearm effective mass may not work on your design. Your tonearm effective mass may be lighter than appeared. Your unique design threw conventional wisdom out of the window. That's one creative idea.
Old 3rd April 2006, 09:38 AM   #18
Attached with the turntable(a modified Gyro back in 1992 where the sub-chassis was my design back in 1982 in one of my diy turntable) with the unipivot+bluepoint(in function) and the SyrinxPU3+Benz micro silver(as a reference).Stability is the key factor of this arm,and I love it This combination does not shy before the Syrinx PU 3.Anyway there are areas need to be reconsidered and rethought for further perfection.And his second and third (my modified version---Wmincy's father) versions will be coming up soon.
Old 20th September 2007, 05:32 PM   #19
fergs1 is offline fergs1  Australia
Greetings, have there been anymore developments with this design. Its a real corker.Well done
peace and goodwill fergs
DIY Unipivot - ClearTone deltavektor Analogue Source 7 15th October 2008 07:31 AM
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 10:49 PM
More unipivot questions... GhettoSQ Analogue Source 12 26th July 2006 09:19 PM
Frank's diy Unipivot arm is about due ? ktigerb Analogue Source 2 28th July 2003 08:44 AM
DECCA unipivot tonearm Merijn Analogue Source 19 3rd February 2003 11:07 AM
Page generated in 0.11031 seconds (77.62% PHP - 22.38% MySQL) with 11 queries
