| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#21 | |
cables" in the ad.
#22 |
I really like the picture where the power supply caps are seemingly sleeping on a little pillow tired after being mounted tilted in a too low clearing height. The connectors come in at the far end and the power cables have to be pulled from the input connector side along the underside of the power supply and up to the transformer. A perfect way of having the AC lines from the power supply close to the tracks...
Elso, Now, it wouldn't be prudent to have naked men on the picture would it? As for the ladies I think they are probably originally from Scandinavia so cold is just when you're sneezing and nothing else for them... /UrSv |
#23 |
diyAudio Retiree
This stuff is all occult including the involvement of Aleister Crowley.
Definitely not for me, Fred |
#24 |
UrSv,
i have at your pix. But i did not see enough ![]() However, i ought to put you in sin bin jut for bad taste ...
Greets, Bernhard |
#25 |
But the question remains: why is the company called Coph Nia?
I suppose it is not named after a band, and they probably do not want to be associated with the picture UrSv found either, or is is just my inability to understand marketing?
#26 |
diyAudio Senior Member
Why not send them an e-mail? Cheers,
Frank |
#27 | |
Electrons are yellow and more is better!
No and then I ask manufactures/designers and surprisingly they answer most of the times!
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#28 | |
-the cheap Trigon Vanguard uses an LT1028 at the front, and 5534 at the back. -the MkI Michell/Trichord Delphini and Delphini Mono used the LT1028 at the input. The MkIIs use a different chip. From my limited experience with these it seems that the 1028 simply adores low-output MCs at its input. |
#29 |
| Greetings from Sweden! | quaddo1 | Introductions | 4 | 18th June 2007 12:05 PM |
| Greetings from Sweden | paradigm | Introductions | 6 | 19th August 2004 02:37 PM |
| Hello from Sweden | hepcat | Introductions | 2 | 23rd September 2003 05:27 PM |
| Greetings from Sweden! | nuppe | Introductions | 10 | 22nd September 2003 05:07 PM |
| New guy from Sweden... | EngelholmAudio | Introductions | 10 | 14th February 2002 12:39 AM |
