Where can I get a neon lamp for Garrard 401?
Old 9th March 2006, 07:29 AM   #1
happycat is offline happycat  Canada
happycat's Avatar
Default Where can I get a neon lamp for Garrard 401?
Could someone tell me where I could get a 120V neon lamp of the E14 type (16x54mm) from North America? I found a source in Germany but the shipping is ridiculous! No one is going to pay 50 Euros for a neon lamp!?
Perhaps someone could enlighten me on this issue? I don't want to spend more than $10 on a lamp.
Happy listening
honinbou
Old 9th March 2006, 07:35 AM   #2
happycat's Avatar
Perhaps someone from Taiwan could help me out here: E14 neon 110V lamp by fimex corp.
http://www.fimex.com.tw/html/product...id=8&itemid=40
Old 9th March 2006, 08:45 AM   #3
Nordic is offline Nordic  South Africa
Nordic's Avatar
I checked RS components seems they only have 240V ones these days but they are only about $3.
Old 9th March 2006, 02:46 PM   #4
rayfutrell is offline rayfutrell  United States
Go to Radio Shack or the Canadian equivalent. Any electronics parts store should have neon bulbs. The big electronics companies such as Newark and Digikey sell by mail but they usually have a minimum order amount.
Ray
Old 9th March 2006, 03:34 PM   #5
dnsey is offline dnsey  United Kingdom
Just buy a bare neon 'capsule' and fit (with appropriate resistor) to your existing lamp base.
Old 9th March 2006, 03:36 PM   #6
happycat's Avatar
Thanks guys. I checked online retailers like Newark Canada and Digikey. They offer only US neon lamps like the NE2, NE52 etc. The local Radioshack shop doesn't even stock neon bulbs!
I still have a 220V bulb in working condition, but it wouldn't work at 120V. The turntable's lamp socket is for European type thread bulbs. Hope one day I could pick up one from eBay.
Old 9th March 2006, 04:26 PM   #7
Basically, all neon lamps are the same except for the current limit resistor in series with the neon lamp. If I recall correctly, you use 47K resistor for 220 volts and 22K resistor for 110 volts.
I'll check and verify.
Ray
Old 9th March 2006, 04:32 PM   #8
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default bulbs
You might try here:
http://www.donsbulbs.com
none
Old 9th March 2006, 04:44 PM   #9
Bobken is offline Bobken  United Kingdom
Ray,
The series R can vary, in accordance with different neon 'bulbs'.
However, in every case I have known, the series R for a 110v bulb will be approx. 1/3rd. of that for a 240v equivalent.
E.G. : 100K/330k, 220k/750k, 56k/180k, 33k/100k. (1st. # is for 110v and 2nd. for 240v).
If the resistor is separate (i.e. not included in the bulb unit) it should be safe enough to replace the original R used for 240v, with one of 1/3rd of this value.
Bob
Old 9th March 2006, 04:57 PM   #10
Hi honinbou,
If it helps, a UK Company [www.lampco.co.uk] lists several E14 neons from only about US $2 each.
I don't know if they will export, but if not and you are stuck, do you know anyone over here who could order one or two and send it/them to you in a jiffy bag, perhaps?
I hope this helps.
Bob
Where can I get a neon lamp for Garrard 401?Hide this!Advertise here!
Neon Power? Trout Tubes / Valves 12 29th April 2006 07:03 AM
neon lights Jordo Car Audio 1 21st November 2005 06:24 AM
Neon Green Speakers ralph-bway Swap Meet 0 9th August 2004 04:43 AM
Neon tube question dhaen Everything Else 17 9th April 2004 11:24 AM
Copyright ©1999-2017 diyAudio
