| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I just bought an Oracle tonearm. Please post your experience of this tonearm. I noted that the VTA adjustment similar to VPI and Tri-planar tonearms. When did Oracle came out with this arm? It seems that there was some looseness in the VTA mechanism when the lock nut was loosen for VTA. This looseness in the VTA column can change the VTA after tightening the lock bolt. I wonder if the VPI and Tri-planar exhibit the same problem also. Thanks
#2 |
as far as I know Oracle do not make tonearms. Are you talking about the rebadged SME ? /sreten.
#3 |
This is the picture of the arm.
#4 |
That is a Graham unipivot.
Hmm well maybe... think my first thought might not be correct. Its a unipivot and it has several Graham like design features including the headshell shape - but it's missing the lateral counterweights... not sure now... James |
#5 |
It is a gimbal bearing arm. I bought it without the needle bearings for the vertical plane motion. I used needle bearings from another arm and it worked fine.
#6 |
It is the Oracle "Prelude" tonearm. I hope you paid very little for it.
As the owner of an Oracle turntable, I can tell you that it is inferior in every single way to later SME/Oracle 345 tonearms. (mine works well with the SME 309). somehow they felt they could design their own, but simply were not upto the task. Many Oracles here in western Canada were equipped with Rega RB300 or Sumiko Premier "MMT" or "FT3" tonearms, the Preludes really never worked or more importantly didn't sound right.
stew ☮ -"A sane man in an insane world appears insane." |
#7 |
Well there you go...
Thanks for the update - one more to add to the database. ciao James |
| oracle alexandria turntable HELP! | fortytwo | Analogue Source | 6 | 29th April 2009 08:50 PM |
| Linear tracking tonearm vs. Pivoting tonearm | Don Nebel | Analogue Source | 1 | 4th November 2007 10:49 PM |
| Oracle pwr supply mod advice | moray james | Analogue Source | 0 | 24th August 2005 03:32 AM |
| Oracle MKV motor details please | frank2395 | Analogue Source | 0 | 14th August 2005 11:47 PM |
| Oracle Delphi( Best arm for this dec) | croft | Analogue Source | 32 | 29th June 2004 05:04 AM |
| Page generated in 0.10355 seconds (78.89% PHP - 21.11% MySQL) with 11 queries |
