Can I lubricate this motor?
I'm using a little Maxon 12v dc ironless rotor motor (#9904 120 18105), from RS. It's over 6 years old.
It has begun to run slightly slow. Everything else (battery, voltages, belt, bearing etc) seems ok.
Can I lubricate this type of servo or must I replace it? If I can oil it what is the best lubricant?
violette said:
Hello
NO !
Sewing maschine Oil ist not for Turntable Motor or Bearing Motor.
You can get by me the right oil for Motor and Main Platterbearing.
Use the Thorens Experience.
Just contact me.
Joel
Hmmm..... bit late for such advice.
As far as I'm concerned any oil is better than no oil.
I've used sewing machine oil on synchronous motors,and have used
all sorts of oil for turntable main bearings - doesn't seem to matter.
:0/sreten.
