| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Does anyone know what is the max deviation on the 300Hz test tone on the HiFi News Test LP ?
If it where played on an imaginary perfect TT with 100% accuracy what would be the error ? would we be able to measure 300.0 Hz or 300.000 Hz or what ? Does anyone know where I can get this information ? Thank You. Guilherme. |
#2 | |
diyAudio Senior Member
Hello Guilherme,
If that doesn't turn out to be useful then you could e-mail mr.Ken Kessler.He described it in one of his colums for that mag. Given even the most perfect TT an error smaller then 1% should be possible with the best MC's currently available. Stylus drag can be minimized by using a product such as Stylast which really works as claimed. You would still see spurious resonances of the stylus/cartridge/arm interface:10 to 12Hz overtones depending mostly on the properties of the tonearm in use. Other then that you should come close enough for it to be a good tool for measurement purposes. Hope this helps,
Frank |
#3 |
I guess you know where this is all heading
![]() I'm trying to find out the error at the source, when it was recorded. Thats why I said "an imginary TT", because there is no TT that does not introduce some speed error no matter how small. Do you have Mr. Kessler email ? I've already tried to email Steve, but got no reply. Why do you talk about the quality of the MC ? agreed, bad quality will bring distortion in the wave form but not on the wave length. If you're measuring the period it will still be the same even if it has a slight distortion caused by resonance. 1% ?? why would you have such high error ? even my entry-level TT has a (claimed) speed variation of 0.08% (which I have not measured yet). I submit that if the test tone has been recorded with good enough precision, then it is a very good way of asserting the speed of the TT. Or am I missing something ? Guilherme. |
#4 | ||
Hello,
Actually I don't have anything usefull on Ken,it's been years since I last had a chance to talk to him. I also discovered they don't have any archives online either,too bad. Quote:
That info comes from Ortofon and is related to their MC 5000. No direct relationship with what you're trying to measure. At this moment you're focussing on speed stability but I was painting a broader picture so you can take more factors into the equation. See you,
Frank |
#5 |
Hello,
Think these people may be able to help you with the testrecord: http://www.britishaudio.co.uk/proaud...iesothers.html Also check this out: Pure Cycle - Turntable power supply, ultra quiet & stable http://www.britishaudio.co.uk/proaud...ssoriesbd.html See you,
Frank |
#6 |
British Audio were the people I got the LP in the first place! Now why didnt I think of that
![]() I just sent them a mail and also Ben Duncan. Hope any of them can help me. The Pure Cycle looks very nice. PS: been busy with my design. Just got hold of a 2.5 ppm oscillator and I'm expecting my circuit to perform at least with 3 digit accuracy. Biggest problem now is to deal with EMI since the design is mainly digital. Again, Thanks. Guilherme. |
#7 |
Hi Guilherme,
Although I admire your search for perfection I believe there isn't much point in surpassing the precision of the cutting lathe. I feel that if you get a reasonable stability with respect to that you're in very good company. And I will pump the net on info on the Neumann cutters tomorrow. See you,
Frank |
| Studiomaster Test tone | Mini_Dub | Everything Else | 1 | 29th July 2009 07:23 PM |
| how can i test a capactiors tone Charteristics? | prorms | Everything Else | 4 | 19th June 2008 05:45 PM |
| Your free test tone CD | DrFrankenstein | Music | 0 | 8th February 2007 09:20 PM |
| Whats worse, 1db error in response curve or a phase error of 6? | primalsea | Multi-Way | 5 | 13th May 2003 01:24 AM |
| Page generated in 0.10503 seconds (77.96% PHP - 22.04% MySQL) with 10 queries |
