Old 8th February 2006, 05:53 PM   #11
tubenut is offline tubenut  South Africa
tubenut's Avatar
The 300 supposedly has better quality bearings and the spring applied stylus pressure helps to ride warps. If you do not like the spring method you can turn it all the way up and effectively out of operation and set force by moving the copunterweight with a gauge....
I believe good value is the RB300 with the tungsten counterweight and stub. Available on request from Rega and from Moth.
Guillaume
Croak Audio Exploration
Old 8th February 2006, 05:58 PM   #12
tubenut's Avatar
Forgot... Plastic mounting base on 250, steel on 300. Thread also seems a different material...
Guillaume
What RB250/RB300 counterweight mod? Shaun Analogue Source 16 11th January 2013 08:15 PM
RB250 or RB300 planarboy Analogue Source 40 24th June 2007 08:53 AM
Best variant of Rega RB250 to use? Glowbug Analogue Source 0 22nd December 2006 07:54 PM
rb250 printable protractor dhole Analogue Source 2 7th April 2005 01:39 PM
TD150 and RB250 frankmalz Analogue Source 1 17th September 2004 05:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
