diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Inverse RIAA (http://www.diyaudio.com/forums/analogue-source/73211-inverse-riaa.html)
davidsrsb 3rd February 2006 07:04 AM
Inverse RIAA
2 Attachment(s)
This is my passive RIAA network for testing mm preamps with nominal 47K input. It has an attenuation of 38dB at 1 KHz so it can be fed direct from a cd player. Nominal accuracy is +/- 0.2 dB to 20 KHz.
Output impedance is low enough not to be affected by any cartridge loading capacitors
EC8010 3rd February 2006 09:50 AM
2 Attachment(s)
A few points. Most CD players have an output resistance of a few hundred Ohms and that will affect your response. Your graph seems to indicate errors larger than 0.2dB, but you have the figures. Even so, 0.2dB error is quite large for a design error - let alone once the effects of component tolerance are factored in. Loading capacitance on any inverse RIAA network will effect HF response. Once it exceeds 200pF or so, you will see errors begin to creep in.
This network has a design error of <0.01dB DC to 100kHz (includes 3.18us) and the worst possible combination of component tolerances produces an error <0.1dB.
davidsrsb 3rd February 2006 11:46 AM
A couple of hundred ohms output impedance won't have any effect in the audio band.
I tried adding 220pF on the output to represent the higher end of typical cartridge loading and it has negligible effect below 20KHz.
I wanted a reasonably accurate design using common component values that were readily available in 1% tolerance.
Your circuit is suitable as a laboratory standard but the values won't be so easy for hobbyists to get.
davidsrsb 3rd February 2006 12:43 PM
Simulating EC8010s circuit, it's ruler flat until it roles off with -0.6dB at 20 KHz and -3dB at 50KHz
EC8010 3rd February 2006 01:00 PM
That's right, it's -3dB at 50kHz to emulate the 3.18us roll-off included in Neumann cutting lathes that protects the cutting head.
pinkmouse 3rd February 2006 01:11 PM
Yes, but it's small enough to use several series/parallel components to get the required valus, with very little extra cost.
EC, I note your circuit is optimised for 50/75 Ohm impedance. Do you have a version better suited for the normal 2/500 Ohm output of ordinary CD players?
SY 3rd February 2006 01:19 PM
Mouser has them.
EC8010 3rd February 2006 01:56 PM
2 Attachment(s)
It's more that the total series resistance before the RC networks needs to be 2197 Ohms. If you knew the output resistance of your CD player, you could simply subtract it from that total value to find out what value of resistance to substitute.
Oh, and to forstall your next question, here's the PCB layout I used...
davidsrsb 3rd February 2006 02:45 PM
I have heard of the Neumann pole arguement, (mainly used to justify non-inverting amplifiers without the extra pole to keep roll off going). Was there much real signal much above 20KHz? I think MM cartridges are not going to have much output up there apart from distortion harmonics. I am a great believer in not amplifying rf signals needlessly with so much 25KHz plus around from ADSL and Internet over Powerline.
EC8010 3rd February 2006 03:01 PM
I normally use passive RIAA (which doesn't have the non-inverting amplifier problem). Also, I use an MC cartridge...
My justification for implementing 3.18us is that phase response is affected a decade away from a turnover point, so phase at 5kHz is affected by the 50kHz zero. I take your point about all the muck past 20kHz, though.
There's another argument for implementing 3.18us in inverse RIAA, and that is that the passive network can't keep HF rising indefinitely (I'm sure you realised this). You have to trade HF against 1kHz loss. If we have to do that anyway, why not make the failing a virtue and match it to the Neumann head?
Copyright 1999-2017 diyAudio
