Inverse RIAA
Inverse RIAA
Old 3rd February 2006, 10:39 PM   #11
burbeck is offline burbeck  United Kingdom
hi try this http://waltjung.org/PDFs/A_High_Accu...AA_Network.pdf
regards
bob
regards
bob
Old 4th February 2006, 01:46 AM   #12
davidsrsb is offline davidsrsb  Malaysia
Thanks, I remembered that article but didn't kow where to find it.
Fortunately a 50KHz zero is not going to have much group delay error below 20KHz. The modified RIAA IEC warp filter pole is another story.
Old 4th February 2006, 09:43 AM   #13
R.I.P.
The newer warp filter is not used at the recording stage, it is only recommended for playback.
In my view the IEC version and some with slightly extended bass response ruin a major attribute of vinyl playback. Avoid it if possible and mimic the old style curve.
Your inverse RIAA should be based on the recording curve and since you plan to use it for tesing other RIAA stages I suggest you aim for an accuracy about 10 times better than the prototype circuits. At least then you will know with a reasonable certainty that errors are in the prototype and not in the reference.
This will require resistors to about 0.1% and caps about 0.5% (absolute not just matching accuracy) or better if you can achieve it (I don't know how), but I'm all ears.
Do your best to keep it very accurate. You are only building it once and only one channel.
By the way you can achieve tiny corrections by paralleling resistors many decades apart. The bigger one then does not need to be precision, 1% will do.
regards Andrew T.
Old 4th February 2006, 10:38 AM   #14
Zoran is offline Zoran  Serbia
Hi
For the simulation I used
the Haggerman inverse riaa
maybe it will help...
Old 4th February 2006, 07:45 PM   #15
there is the original PDF
by Jim Hagrerman...
and ZIP file contains
some upgrades from audiophile called "Ouch"
interesting...
Old 4th February 2006, 07:53 PM   #16
I am using modified inverse RIAA net
for the simulations...
note:
only two RIAA networks are show normal results
1. Morgan Jones all in one network
2. LC network by western electric
the zip file is too long...
here is web address if it is still on line...
http://www.siteswithstyle.com/VoltSecond/index.html
cheers
Old 5th February 2006, 04:59 AM   #17
hagtech is offline hagtech
hagtech's Avatar
Zoran,
Thanks for pointing out the original. I was wondering why the EC8010 circuit looked so familiar.
jh
Inverse RIAAHide this!Advertise here!
lcr riaa Raj1 Analogue Source 2 24th April 2014 10:56 AM
Inverse RIAA revisited Pjotr Analogue Source 0 28th December 2007 02:32 PM
inverse horn for omni directional? killerfishes Multi-Way 20 18th June 2005 06:30 PM
An inverse-attenuator inteificio Analogue Source 0 14th December 2004 06:03 PM
Inverse RIAA Hoffmeyer Solid State 7 24th November 2001 04:54 PM
