Old 30th October 2002, 01:35 PM   #11
diyAudio Senior Member
fdegrove's Avatar
Default DAMPING
Peter,
Have you tried hammering some nails through your fingers and then rest the transport on their points?
Ok,ok,I'm out of here.
Frank
Old 30th October 2002, 01:36 PM   #12
Default suspended deck
bm_mode
I think you are correct, amplitudes would be less with higher mass.
My thinking is,with a more complex platter construction and good
choice of materials it is possible to achieve faster decay of
resonances and higher natural frequencies-compared to e.g. a
plain acrylic plate.
Richard
Old 30th October 2002, 06:58 PM   #13
fddegrove
Thanks.Why do you hang aroud here?
Richard
Old 30th October 2002, 07:09 PM   #14
fdegrove's Avatar
Default Err?
Richard,
Is this what you mean?
I was making a joke between Peter Daniel and myself.
I'm pretty sure he understood it,after all , once in a blue moon we have a good laugh as well.
Frank
Old 30th October 2002, 07:18 PM   #15
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I never miss an opporunity for a joke either. After all that's why we are all here, right?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th October 2002, 07:21 PM   #16
fdegrove's Avatar
Default KIDDING
Hi Peter,
See you later,
Frank
Old 30th October 2002, 07:49 PM   #17
Peter,Daniel
O.K. now I know what diyaudio is all about.
Richard
Old 30th October 2002, 08:07 PM   #18
I believe, that in order to be able to create a great design a sense of humor is necessary. Being too busy with details, one might miss a big picture.
www.audiosector.com
Old 30th October 2002, 09:30 PM   #19
Default supermodel
Now I REALLY understand!
Richard
Old 30th October 2002, 09:36 PM   #20
Getting back to your deck, did you try hard suspension?
In case you didn't see here's the link to my deck: CD PRO 2 - The making of a high end CD Transport
I tried soft suspension, but achieved better sonics with hard suspention. It was not easy though and I had to experiment a lot with supporting platform. Finally a sandwich of two granite slabs with blown rubber in between worked well. My inspiration came from a man behind 47 Laboratory:
"The platform/casing of Flatfish is a 2/3 inch thick, machined aluminum board. All the driving mechanisms, pick-up mechanisms and the circuits are directly mounted on this one piece of aluminum board.
The huge difference between the mass of the mechanisms and that of the platform (150g against 1200g) enables to cut off the vibrations caused by the slight off-centering of the disks and the tracing mechanisms returning to the bit-tracing lens itself, allowing us to minimize the amount of servo control dramatically.
This rigid and compact structure of the platform has a very small surface area to receive the vibrations, and its large mass helps to reduce the vibrations smoothly and effectively without any extra damping or suspensions.
As a result, storage of vibration energy was minimized, letting us achieve a refreshingly quick transient response. Compared to the conventional box-type chassis/casings, this platform is almost completely free from any stress of construction. Now, you can hear how much harmony and bottom-end information was obscured under those mechanical stresses."
www.audiosector.com
Magnetically suspended DIY tonearm marekst Analogue Source 76 16th April 2012 04:27 PM
acoustically suspended or not MCPete Multi-Way 15 30th June 2008 10:06 AM
Plate with suspended shelf Sabas Analogue Source 2 31st October 2006 04:02 PM
suspended turntables - set-up Timbo in Oz Analogue Source 2 16th June 2004 01:14 PM
Copyright ©1999-2013 diyAudio
