TT from Rega bearing and motor - Page 2 - diyAudio
Old 21st December 2005, 07:25 AM   #11
Sella is offline Sella  Finland
Originally posted by graeme uk
i have a planna 2 if you want me to weigh anything ect. Dont mind taking it apart either.
Yes, that would be really kind. Do you have the glass platter? It would be nice if you weigh it too.
I think that Planar 2 has smaller main bearings than P3. Something says to me that Planar 2 bearings are only 12mm ja Planar 3/P3 has 18mm. I am not sure if this is true?
Old 21st December 2005, 10:37 AM   #12
the bearing is 8mm, that is the rod that slides into the bronze bush in the plinth is 8mm diameter.
The glass platter is 10mm thick and weighs just under 1.7 kg
Old 21st December 2005, 11:42 PM   #13
tubenut is offline tubenut  South Africa
tubenut's Avatar
I also have schematics for Rega's circuit to achieve less vibration result with this motor (practically just caps which changes the phase to different coils of motor).
Could you post or explain the cct?
The original cct are just 2 x 0.22 MFD caps on each winding. The new rega cct allows hard coupling of the motor on to the plinth. The 2 caps supply is still the dangle from an O ring mounting.....
Old 20th March 2006, 04:05 PM   #14
The plinth is almost ready now and I am thinking the assembly of the Premotech motor.
Is it a good idea to cast the motor into bitumen? Sealing any holes in the motor first naturaly. Does it cause overheating or other malfunctions?
I am going to hardmount it to the plinth with a sticky paper (like in P3) put filling the motor cutout with bitumen would in my opinion absorb vibrations.
What do you guys think?
Old 16th February 2011, 03:18 PM   #15
Hi Sella, now, in 2011, I ask you for the simple circuit that controls the rega motor.
My actual circuit ( cap + resistor ) make the planar a little fast.
Thank you in advance, Claudio
Hard drive motor as a bearing YAKI Analogue Source 3 3rd March 2009 09:17 PM
Linn to Rega bearing conversion. sq225917 Analogue Source 13 29th April 2008 10:36 PM
Rega Rb300 bearing question cwujek Analogue Source 5 30th January 2008 02:52 PM
Motor / Bearing hifido Swap Meet 0 13th November 2006 05:38 PM
Rega Planar 2 Bearing Redart Analogue Source 1 9th April 2006 10:19 AM
Copyright 1999-2017 diyAudio
