The NSSPS (Not So Simple Phono Stage) - diyAudio
Old 2nd November 2005, 08:22 PM   #1
dsavitsk's Avatar
Default The NSSPS (Not So Simple Phono Stage)
Maybe someone else has already preoposed this, but if not, here is the Not So Simple Phono Stage (NSSPS). It is based on the Very Simple Phono Stage (VSPS) but has the addition of a buffer to the opamp which helps drive long cables and, more importantly, allows the opamp to be biased into class A. The buffer on its own did little to the sound (and in fact may have hurt it a little) but biasing the opamp into class A did wonders for me. (The trick is that you need the buffer there for the biasing to work.)
It took this project to the next performance level. One caveat is that you will need to increase the rail caps a bit since the class A nature is drawing more power. I added a second set of 220uF caps to each rail in addition to the 220 suggested in the VSPS. (I also built dual mono power supplies, so with a single supply, that is close to 1000uF per rail.) I also added .33uF film and foil caps very close to the opamp/buffer pins. I could see adding more electrolytics and an extra .1uF to the pins as well as there may not be enough bass for some -- probably depends on your table. For the CRD, I used a monolithic 0.56mA CRD as I had it on hand. I am going to experiment with some larger values as well, but using a jfet pair is also a good way to go.
Old 3rd November 2005, 02:50 AM   #2
hacknet is offline hacknet  Singapore
is it possible to have the feedback loop with the riaa before the buffer instead of after...?
Old 3rd November 2005, 03:25 AM   #3
BrianL is offline BrianL  United States
I would hope that anyone doing RIAA equalization would refer
to Linkwitz's papers on the topic before choosing a feedback/EQ
topology.
As to the location of the feedback, this circuit is just fine as
is. One thing it does for you is relieve the OPA627 of the
burden of driving the falling impedance of the feedback
network as frequency goes up. Driving an RIAA feedback
network is just the thing you don't "want" to do with
most amplifiers. Open loop gain is dropping off with
frequency while load is increasing.
bel
Old 12th November 2005, 03:49 PM   #4
doggy is offline doggy  Canada
doggy's Avatar
Hello everyone
This may not be on topic but I am looking for some suggerstions and help. I want to build a phono stage using opamps. The plan would be to use a socket so I can use different opamps; also to be able to have ample gain for mm cartridges. My budget is somewhat limited, a proven pcb is an option or I could build on a perf board. Any suggestions for a good sounding phono stage would be appreciated and also where I could get the pcb and hard to find parts.
cheers
doggy
Old 13th November 2005, 12:10 AM   #5
dsavitsk's Avatar
The VSPS that was the basis of this project can be found here: http://www.geocities.com/rjm003.geo/.../diy_pho5.html It is very easy to build and allows some opamp rolling.
Another similar option is the El Cheapo phono: http://www.users.nac.net/markowitzgd/phonopre.html
This project (that the thread is about), to my ear, sounds a bt better than the VSPS, but it does require a few extra parts. Also, while it iworks well with the OPA627, it does not like the AD643 which tends to lock up.
I have attached the schematics and a few pictures.
Old 13th November 2005, 12:11 AM   #6
dsavitsk's Avatar
power supply
Old 13th November 2005, 12:13 AM   #7
dsavitsk's Avatar
Old 13th November 2005, 12:14 AM   #8
doggy's Avatar
Thank you kind sir, will have a good look at this.
cheers
doggy
Old 13th November 2005, 12:16 AM   #9
dsavitsk's Avatar
Old 13th November 2005, 12:19 AM   #10
dsavitsk's Avatar
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
Low-V simple phono stage + tube buffer iko Analog Line Level 0 12th October 2008 12:45 PM
Simple phono stage (MC) Onvinyl Analog Line Level 5 9th August 2008 09:50 PM
Simple tube phono stage ambience exists Tubes / Valves 8 27th June 2008 02:29 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Copyright 1999-2017 diyAudio
