Noisily front end Noisily front end - Page 2 - diyAudio
Noisily front end
Noisily front end
Old 16th January 2006, 01:57 AM   #11
mantistube is offline mantistube  United States
There may be several problems here!
It doesn’t sound like it is just Hum. There may be some acoustical issues going on too. While the table is in a solid and heavy plinth made of layers of furniture plywood clamped together with ˝ inch steel threaded rods, it is on a flexi-stand (http://www.tnt-audio.com/clinica/flexye.html) from the TNT site. I have another stand made with 3-inch sand filled tubes and topped with a sand box. Once I finish leveling it I will try that.
I also wonder about the turntable itself. The platter could be of some magnetic material. Could there be some interaction between the cartridge and the platter?
You know I wonder if there is a general grounding problem going on. When I think back to when the renovation was being done that the Romex or AC cable only had 2 lines. Aren’t AC lines in the US, suppose to have positive, negative and ground? I wonder if this is the issue. So I am creating a ground. I have a piece of the 10 gauge solid core that I have connected to the cold water return on the radiator (old house remember). You know before the Loesch I had a Foreplay preamp (by Bottle head). It really did sound great but the Hum was terrible. Tried a couple of the ground techniques the site offered but with no luck. It ended up in the “failed projects pile”. Now with my issues with the other preamp I am being to wonder if the room is the problem.
Getting back to the issue at hand. I am trying to resolve the grounding issue. When I put the needle in the grove and turn the volume up I am hearing hum. The tonearm (SME 3009 II) has ground cable and is attached to the table. It other end is attached to the preamp. There are no connections between the amps and the preamp. Should there be?
Anybody know a website on how to ground?
Noisily front endHide this!Advertise here!
j.fet front aleph 5 slr 5000 Pass Labs 7 2nd July 2009 03:10 PM
A75 front-end collapsed ckwong99 Pass Labs 20 3rd October 2005 06:24 AM
Front end for sub amp mashaffer Solid State 9 22nd July 2005 03:35 AM
Front Panels jackinnj Everything Else 0 20th October 2004 07:23 PM
searching software to switch front speakers to rear and rear to front!-dolby surround MCM Everything Else 6 6th February 2004 09:29 PM
Copyright ©1999-2017 diyAudio
