| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I have a faulty FX1100BK. After years and years of good service it
drops out after a few minutes of playing. I did find a part of the schematics on the yaho tuner site. If I do DC measurements out of the "regurator" board (not on the schematic) into the powersuply part of the main board (on the schematics)Iget DC readings way above the indicate ones. Some parts do run very hot. Does someone has the full schematic of the "regurator" board available, or even better the complete service manual? Any other help or suggestions would be welcome. Regards earsandeyes |
#2 |
my first suggestion would be to go in and do some soldering at the regulators and the output section. loose components will drive one crazy.
#3 |
#4 |
Thanks for the directions of the schematic. Problem is that the one you will find there is not complete. The people from the JVC service centre were so kind to send me the complete set as PDF.
Still having problems though. Replaced some parts that seemed faulty (leaking caps). No succes. The schematic is hardly legible. Have put the thing aside for a while now. I asume there is (are) zener(s) faulty, cannot read the right values. earsandeyes |
| Faulty NAD 4100 Tuner - help & suggestions needed | stevecole | Analogue Source | 0 | 7th May 2009 09:39 PM |
| Tuner LPF Korin BL-13 needed | 2ndserve | Parts | 0 | 14th April 2009 03:44 PM |
| Sansui TU-777 Tuner Schematic Needed | Algar_emi | Analogue Source | 0 | 16th January 2009 12:32 PM |
| Larsholt fm tuner front end for JLH tuner design-Any still available? | djsb | Analogue Source | 0 | 25th December 2008 04:46 PM |
| Sansui TU-X1 FM Tuner : Service Manual Needed | bordins | Analog Line Level | 1 | 4th March 2006 01:26 PM |
| Page generated in 0.08346 seconds (71.80% PHP - 28.20% MySQL) with 10 queries |
