Old 14th June 2011, 01:04 PM   #41
PhantomBox,
Do you get signal on the "dry" side of the Space Echo? You know, with no echo added?
How old is this tape you're working with? I've had audio restoration jobs where the tape was only playable a limited number of times because the oxidation ate away the magnetic coating and the process of rolling through the rollers would flake off the recorded audio. I doubt you have such a case but still, oxidation will hinder a tape's ability to take on new sound. Not to mention that in the cassette heyday you could only get a limited number of "overdubs" before audio quality dropped off substantially.
Can you A/B it with a new tape?
relapping tape heads with 3M scouring pads??? honinbou Analogue Source 9 26th September 2009 02:17 PM
FS: Sony TC-777 parts... motors, tape heads etc. honinbou Swap Meet 0 4th January 2009 07:19 AM
Alps TAPE!! heads DragonMaster Analogue Source 2 16th August 2007 01:50 PM
De-magnetizing tape heads Sir Trefor Analogue Source 13 20th June 2005 02:29 AM
About tube tape recorder heads walk Tubes / Valves 10 28th September 2002 09:22 PM
Page generated in 0.07096 seconds (68.16% PHP - 31.84% MySQL) with 10 queries
