| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#51 |
That's a good idea - however, the arm has moved on a little in the last year and a half.
I'm still using it though. The arm wires are still those from the autochanger, and go from the top of the arm above the pivot in an 'n' shape to the plinth, where it attaches directly to the phono lead. That runs to the amp as normal. The phono stage shown there has been consigned to the shelf, awaiting, in all probability, parts scavenging and disposal. The deck, VHS head drum and the 'headshell' coin are connected together and earthed via a separate wire to the amp. I get no hum at all - just the whooshing noise of the phono stage. I have re-mounted the armboard to move the pivot a bit closer to the spindle, to improve the alignment of the cartridge. I also added an antiskate mechanism - just a piece of thread round the drum, over a wire hook and down to a weight (experimentally decided as needing to be 2 drawing pins). I will put some more photos up at some point but being in the middle of exams doesn't leave much free time. James EDIT - I love your signature, EC8010. |
#52 | |
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| 3 Tonearms and a cable box CHEAP | Antripodean | Swap Meet | 0 | 13th March 2009 10:05 AM |
| technics SL 1200 MK3D tonearms | flip | Analogue Source | 4 | 6th September 2007 01:43 PM |
| Grace 707 & JH 4 tonearms for parts | woody | Swap Meet | 2 | 19th December 2005 10:17 PM |
| Really ignorant question about tonearms. | G | Analogue Source | 2 | 10th September 2004 08:08 PM |
| Continuation of 8" 45L sub with low end EQ | moving_electron | Multi-Way | 7 | 10th May 2004 05:48 PM |
| Page generated in 0.10007 seconds (60.82% PHP - 39.18% MySQL) with 11 queries |
