Upgrade Platform for my Tecnodec
Old 1st October 2005, 08:15 PM   #1
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Default Upgrade Platform for my Tecnodec
During this weekend, I'm building an upgrade mounting platform for my new Tecnodec turtable. Inspired from the Roksan upgrade platform, see:
http://www.everestaudio.com/price-pa...ade-Plinth.htm
The purpose of this plinth is to support the table and its motor, to lift the table and by clearing the arm mount section, to give an easy access to the VTA nut adjustement. I will also terminate the Cardas upgrade tonearm wires to a Cardas type RCA connectors mounting block. Then I'll be able to use my choice of tonearm interconnect wires, see for an example:
http://www.takefiveaudio.com/mall/Tu..._box_cpib.html
I'll build my own alu mounting block and buy only the Cardas RCA connectors.
My Upgrade Power supply will seat on the side of the platform, see: http://www.diyaudio.com/forums/showt...0&pagenumber=3
My version is a laminate of two high quality birch plywood layers(0.75" and 0.5" = 1.25" total) + 1/2" of MDF on the bottom and finally a layer of 1/32" aluminium.
The aluminium is brushed then alodined.
Everything is glued together under pressure, here the assembly
Old 1st October 2005, 08:18 PM   #2
Algar_emi's Avatar
The bottom MDF layer has 5 holes in it. It can install 4 feet at each corner or 3, two on front and one in the rear.
The feet can be use to level the platform. A bulb lever will be mounted on the platform.
The feet will be terminated by brass cones.
The adjustable feet screw into T-Nuts mounted on the inside of the MDF layer, here a detail
Old 1st October 2005, 08:19 PM   #3
Algar_emi's Avatar
Here a side view, without the aluminium when starting the finishing with teinted oil vernish.
Old 1st October 2005, 08:28 PM   #4
Illusus is offline Illusus  Canada
Illusus's Avatar
should work very well, nearly identical construction to a plinth I built for some Thorens TD-16x hardware I salvaged. The only difference is that I crammed a layer of cork into the sandwich. Sounds great. I like the look of open multi-ply, I'm reworking most of my gear to carry that theme through-out. "It's like Sweden, Jerry! Sweeeeden!!"
Fighting the program since 1976.
Old 1st October 2005, 09:19 PM   #5
Algar_emi's Avatar
Thanks for the kind comment. Wait until you see the final look. It is great
I can't wait to try it. Still waiting to get the money to buy the cartridge thought
Bye...
Old 1st October 2005, 11:51 PM   #6
Illusus's Avatar
which cartridges are you looking at...I may have something decent I can spare.
Old 3rd October 2005, 01:04 PM   #7
Algar_emi's Avatar
I'm looking to buy an Benz Micro ACE low output, but I can use anything else in the mean time I guest. I built an Pass Labs ONO clone as phono preamp, so I can accept a wide range of output.
What cartridge do you have available?
Thanks again...
Old 3rd October 2005, 10:06 PM   #8
Illusus's Avatar
YGM
Old 3rd October 2005, 10:11 PM   #9
Algar_emi's Avatar
YGM, what is that mean ?
Old 3rd October 2005, 10:16 PM   #10
Illusus's Avatar
ahh, one of those silly interweb acronyms... You-Got-Mail
Upgrade Platform for my TecnodecHide this!Advertise here!
NeoY2k's ESS Sabre DAC platform NeoY2k Digital Line Level 76 25th February 2011 09:07 PM
The DAC development platform peufeu Digital Line Level 63 23rd May 2009 08:37 PM
My new Analog Rig - Michell Tecnodec Algar_emi Analogue Source 17 10th September 2008 09:07 PM
Cartridge for Michell Tecnodec with a Rega RB300 Algar_emi Analogue Source 7 6th August 2005 03:14 AM
