| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi
I have seen lots of threads about active crossovers here. They all use opamps, I want to try descrete components if possible. I found the attached diagram in an old HIFI magazine and I want to have opinions on this. it is a 12dB/octave, why go for more if the speakers can handle it. The Cf and Rf components have to be calculated according to the formula Fc=1/2*pi*square root 2*R*C. Any comments?? |
#2 |
Line level crossover filters are invariably based on the Sallen & Key topology that you've shown. You only get nice simple equations if the amplifier within the loop has lots of gain. the circuit you've shown should have quite a bit of gain, so it's rather like an op-amp in that respect - it just doesn't have the DC stability conferred by a differential pair input stage.
A very popular configuration is the 24dB/oct Linkwitz-Riley crossover, which is made of a cascade of two 12dB/oct Butterworth filters. The reason it's so popular is that it's insensitive to the fact that the two drivers are not coincident. Finally, all Sallen & Key filters have increased distortion within the pass band compared to that same amplifier configured for the same gain but without filtering. In other words, you want a nice low-distortion amplifier before you wrap Sallen & Key around it.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 | |
#4 |
"it is a 12dB/octave, why go for more if the speakers can handle it."
Below the crossover frequency down to the resonance, the excursion of a hi-pass filtered loudspeaker is constant for constant input to the filter, despite the fact that electric power applied is falling. This is a very good reason to go more than 12 dB/o. ~~~~~~ Forr §§§ |
#5 |
Not coincident means the drivers don't occupy the same point in space.
Sallen & Key wrote the original paper on how to make filters with CR networks and amplifiers, rather than LC networks. The circuit you showed is a Sallen & Key filter. Unfortunately, it increases the distortion produced by the amplifier compared to that amplifier without Sallen & Key around it.
#6 |
As a professional designer of loudspeakers, I would say that at least 18dB/ Octave is preferrable. The problem that you can have with 12dB is the steepness of the slope ( or lack of it). Let's take, for example, a ribbon tweeter. These perform very well in the case of the Visaton MHT12, from around 2500 to 3KHz but, to function correctly, they need quite a steep filter slope say at least 18dB/ Octave. The 24dB Linkweitz Riley crossover is good because it gives you a nice steep slope BUT, you get the equivalent of 1st order phase response.
If it were me, I'd go for the above option. Best of luck. Ricky. |
#7 | |
Dream on !!! Regards Charles |
#8 |
My personal experience is that lower order crossovers, no matter whether active or passive, analog or digital, sound better. Which is a reason to select drivers that don't need steep slopes.
Anyway, probably a matter of taste... klitgt, did you have a look at Nelson Pass' active crossover or the (similar) MOX? They do use opamps, but discrete ones... |
#9 | |
A question: is in-built frequency compensation of opamp really neede for low-pass filter? Or does the filter compensate opamp itself? regards |
#10 |
The frequency compensation is there to achieve a stable NFB-LOOP.
In the case of a Sallen-Key filter where the op-AMP is used as a buffer full feedback (or almost full in case of gain) is applied and therefore the OP-AMP must be stable for the desired gain independant of being used for low- or high- pass. Regards Charles |
| Fully active setup, worth it? | Jussi | Multi-Way | 17 | 9th November 2006 10:02 PM |
| Worth prototyping (headphone amp design) ? | 00940 | Headphone Systems | 9 | 14th May 2006 09:43 PM |
| Box design and Active filter | ocool_15 | Multi-Way | 4 | 2nd May 2006 02:20 AM |
| Trying to design my first active XO | DonoMan | Multi-Way | 9 | 17th October 2005 10:46 PM |
| Looking for simple active XO design | Cradle22 | Solid State | 2 | 8th May 2003 08:07 AM |
| Page generated in 0.11980 seconds (77.42% PHP - 22.58% MySQL) with 11 queries |
