Old 15th September 2005, 08:35 AM   #11
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
klitgt,
I think you will be better off using one of the many designs based on “real” opamps. But if you want a nice discrete opamp try looking here: MOX - active crossover
You should be able to use this opamp with just about any active filter topology you can find.
Good luck
\Jens
Old 15th September 2005, 11:15 AM   #12
Why is everbody talking about opamp, while this guy designed a, what looks like a good, discrete buffer?
the circuit attached in the first post should just work fine, or am I missing simething?
Old 15th September 2005, 05:54 PM   #13
darkfenriz's Avatar
Thanks Charles
I wrote nonsense.
Old 17th September 2005, 01:31 PM   #14
klitgt is offline klitgt  Denmark
klitgt's Avatar
Default Re: Re: Is this active x-over design worth while?
Originally posted by Ricky
As a professional designer of loudspeakers, I would say that at least 18dB/ Octave is preferrable. The problem that you can have with 12dB is the steepness of the slope ( or lack of it). Let's take, for example, a ribbon tweeter. These perform very well in the case of the Visaton MHT12, from around 2500 to 3KHz but, to function correctly, they need quite a steep filter slope say at least 18dB/ Octave. The 24dB Linkweitz Riley crossover is good because it gives you a nice steep slope BUT, you get the equivalent of 1st order phase response.
If it were me, I'd go for the above option.
Best of luck.
Ricky.
What I want to use the filter for is a bi-amp system for "bookshelf" size speakers assisted by subwoofers with a cross-over frquency of 100 Hz. The small speakers are able to go down to 60Hz, therefore I do not believe it is necessary with steper slopes than 12dB/octave.
Fully active setup, worth it? Jussi Multi-Way 17 9th November 2006 10:02 PM
Worth prototyping (headphone amp design) ? 00940 Headphone Systems 9 14th May 2006 09:43 PM
Box design and Active filter ocool_15 Multi-Way 4 2nd May 2006 02:20 AM
Trying to design my first active XO DonoMan Multi-Way 9 17th October 2005 10:46 PM
Looking for simple active XO design Cradle22 Solid State 2 8th May 2003 08:07 AM
Page generated in 0.09745 seconds (68.42% PHP - 31.58% MySQL) with 11 queries
