| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
I only used distilled water or the Lenco fluid (which I think was just water with a little surfactant added). Tap water was not even considered! Terrible stuff. I keep thinking that the water is extracting some of the polar bits or possibly being taken up by the one of the additives to the vinyl, which swells slightly and gets little chips flaking out. Pure speculation.
There's no doubt that better materials are around. Teflon is not one of them- it's slick, but it's terribly soft. I wonder about using PEEK...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#12 |
Retrieved from "http://en.wikipedia.org/wiki/PEEK" :
PEEK is partially crystalline, and has a glass transition temperature of 143 °C and a melting temperature of 334 °C. The material is resistant to both organic and aqueous environments, and are used in bearings, piston parts, pumps, compressor plate valves, and cable insulation applications. PEEK is a thermoplast with extrordinary mechanical properties. The Young's Modulus is 3.6 GPa and its tensile strength 170 MPa. PEEK is also considered an advanced biomaterial used in medical implants. Let´s hope some R & D people are reading this thread Now, about those royalties...
Paulo |
| Vinyl Records | tryonziess | Everything Else | 28 | 26th June 2008 12:50 PM |
| How I missed my records | mashaffer | Analogue Source | 42 | 23rd July 2006 06:16 AM |
| Whr to buy VINYL records? | Tony.ca | Analogue Source | 11 | 6th February 2006 07:45 AM |
| Distortion with GC with some records | reins | Chip Amps | 60 | 7th November 2004 10:52 PM |
| LP Records | David Huang | Analogue Source | 2 | 7th June 2001 05:14 AM |
| Page generated in 0.06732 seconds (71.38% PHP - 28.62% MySQL) with 10 queries |
