What is the best way to adjust Tone Arm
Old 27th September 2002, 01:41 PM   #21
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default ALIGNING
Per,
Maybe we should align any language barriers as well?
I see you're still promoting the "smoerebroet"?
Excuse the spelling.
Frank
Old 27th September 2002, 05:42 PM   #22
Rino odorico is offline Rino odorico  Canada
Peranders! Cool pdf. Just copied it...going to play with it on Saturday. I'll post the results.
Rino Odorico
Old 27th September 2002, 06:24 PM   #23
dice45 is offline dice45  Germany
All,
description of the promised procedure is quite job and tonight i want an evening off.
In the meantime, have a look at this post, Topics: VTA, TF, AS adjusted by ear.
Bernhard
Old 27th September 2002, 11:38 PM   #24
fdegrove's Avatar
Default ADJUSTIN'
Bernhard,
Do you see the use for a "grooveless" record?
Does anyone see the use of a cartridge as an acceloremeter for that matter?
Sometimes people don't realise the power of the tools they have at hand.
Sent us a little post when you're back from the "Bier Garten"
Ciao,
Frank
Old 1st October 2002, 05:20 PM   #25
Default Did some playing on the weekend
Hey all, did some playing on the weeked. Adjusted the Tone Arm and the anti-skate. Already sounds better. Quick question...anyone listen to Gold Dust Women on album (Fleetwood Mac)? Does Stevie's voice get a little distorted and higher levels.
Old 1st October 2002, 11:05 PM   #26
Rino and all,
duties kept me busybusy the last days.
I see that i post the promised Howto as soon as possible.
There has been a question concerning blank bands/grooveless areas on test records.
Yes, to me they make sense as a coincidental check or simply to save time.
The antiskaing adjustment by ear i descibed in my linked post arrives at approximately the same AS values as the blank band test. I say approximately as each record's vinyl is a little bit different concerning friction and this affects the blank band test minutely. Obvious that the blank band record has not exactly the same friction as the record with music on it and used to adjust AS by ear.
Reference to me is the AS adjustment by ear, but the blank band test can save a lot of time to get in proximity of the optimum AS value. No lengthy iterations needed, seek the blank band test AS value for a given TF, then do the fine tweaking by ear. Only recommended if you have a lot of experience with the adjustment by ear, otherwise the iterations to arrive at the right value are sort of teach-in.
Bernhard
Old 2nd October 2002, 08:46 AM   #27
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
Default Clipping turntable
Hi all,
reading all this helped me quite a bit on my way with my 5,- dumpstore turntable It's not much really, but I can play my records for now...
The problem I am experiencing is this: My phono seems to have a difficulty with dynamics. It starts to clip at higher frequencies when say, the singer volumes up. I'm not sure what's the source of this clipping, but I definitely want to get rid of it!
I don't have any measuring tools, but i'm trying to borrow some. Next, since one of the cartridge-holding-screws is missing, I'm unable to adjust the azimuth.
Does anyone know what the primary source is of ths clipping-disaster??
Bouke
More Power Igor! More Power!
Old 2nd October 2002, 08:56 AM   #28
fdegrove's Avatar
Default CLIPPING
Hello,
It is a bit of a wild guess:
Assuming the problem manifests itself on both stereo channels,it could be :
-that the tracking weight of the cartridge is a bit too low.
-the cartridge tip is dirty.
-you're overloading the phonostage,check if it is set for the correct type of cartridge.
Rgds,
Frank
Old 2nd October 2002, 08:56 AM   #29
stefanobilliani is offline stefanobilliani  Italy
A turntable is a very delicate thing ; There are 3 parameters (main) of regolation : the VTA or vertical tracking angle , the parallelism between shell and table , and the radial error.
A wrong regoulation of these parameters ( even a millimeter )
will be as the results , a disaster.
Cheers
What is the best way to adjust Tone ArmHide this!Advertise here!
How do I adjust amp bias? fotzepolitic Solid State 31 22nd May 2017 09:55 AM
QSC 22 Adjust advice please... artcarmo Solid State 18 3rd May 2011 08:49 AM
How can I adjust the tone arm so it does not miss the edge of the record? dac10012 Analogue Source 0 31st March 2009 03:35 PM
Gain adjust? Where? jimbo1968 Chip Amps 5 30th June 2005 04:56 PM
LM350 adjust pin eeka chu Solid State 3 5th February 2004 11:08 AM
Copyright ©1999-2017 diyAudio
