Old 20th August 2005, 06:57 PM   #1
Miniwatt's Avatar
Default My DIY TT - a first glimpse
Hello everyone,
My Scheu bearing and platter finally arrived, couldn't wait for the official plinth to be finished, so i put it all on a piece of wood, just to get a first impression. Arm comes from my Pro-ject RPM 4. Results so far are quite stunning, never knew there was so much on my records!
This is just a short impression, I'll get back when I've made a decent plinth..
Old 20th August 2005, 08:02 PM   #2
Audiofanatic's Avatar
Cool Looking good Miniwatt
Hi Miniwatt,
What type of motor are you using?
What kind of plint are you making? Granite? Wood or Plexiglas?
This looks nice already, wonder how it will look when finished!
Audiofanatic Mooi Man!
Edit: BTW, I see that you have great (audio) taste, V.Medevoort amp and TEAC
Be nice to animals.
Old 21st August 2005, 01:51 AM   #3
Miniwatt's Avatar
Bedankt Audiofanatic / Thanks Audiofanatic
It's pretty much all Scheu, including the motor; DC, very powerful.
All of those!! Not really, plans are : top layer of acrylic, then a few layers of Birch plywood with cavities for sand, and maybe a bottom layer of aluminum -not shure about that one.
And a Ladegaard arm in the end...
Cheers!!
The Van Medevoort preamp is to be substituted by a Triode Dick's 6072 line amp / Phonodude. I think this will be a nice upgrade too... ("Where will it all end????")
The TEAC is my last CD-player I'll buy, can't get any better
Old 23rd August 2005, 09:03 AM   #4
Hi, your Scheu platter and bearing are very similar to my Teres, which has had at least four rebuilds to get where i am now, so can I offer some opinions about plinth designs based on what I have found to work - and not to work?
These are. if course just a personal opinion and I have only been able to try a few combinations so there must be many other possibilities at least as good or better. Hope they might be of some use.
1 my first build was based on plywood layers with lead and sand filled compartments inside. I thought it sounded good until I changed it. In reality it wasbass light with less definition than I got later.
2 High mass alone is not necessarily good as it can just store and reflect energy. A composite material like Corian is one of the best solids because it is made up of materials of very different densities. It also machines with a router using cutters designed for Corian and looks really good (Nottingham Analogue).
3 My best result has been a high-mass base using constrained layer damping - in my case glass/aluminium like the Marantz TT1000. the layers must be very firmly bonded together. The aluminium transmits vibration, the glass constrains the layers and "kills" it. Tip - get the glass cut first and then make the aluminium to it; my local glass dealer only works to +-1mm tolerance!
4 An air-suspension base is easy to make using a bicycle inner tube, but it really didn't work well. When I changed to cone feet the differerence in detail and solidity was amazing.
5 Even given the really large mass of the turntable, when I re-used my original wood-based plinth as a second platform under the plinth, there was a major improvement again.
6 A screw- down record clamp really worked well.
There are some pics of this at various stages at:
http://www.william-reed.net/audio
regards, jeff
Old 24th August 2005, 02:30 PM   #5
Miniwatt's Avatar
Hi Jeff,
Thanks a lot, this is very helpfull!
I typed a long reply, unfortunately something went wrong and it went up in smoke Don't feel like doing it all over again, I'll get back later -after I studied your website, this is great stuff!!!
Old 25th August 2005, 02:45 PM   #6
regards, jeff
Jeff,
yes the Teres is build as a Scheu clone. The Teres folks explicitly reference the Scheu on their DIY site.
Nice web site ! Your Teres implemention reminds me a lot of the Marantz TT1000 turntable with its layers of glass and aluminium.
I had the original Scheu steel base first, and now I am using a homemade very solid wooden base, which sounds a lot more natural to me than steel.
best regards,
Hartmut
Old 25th August 2005, 04:12 PM   #7
Miniwatt's Avatar
Hartmut, I don't know the original steel base, what was it like??
And also I'm curious about your 'solid wooden base', can you give me a description??
This is getting more interesting every day! I think I'll stick around some more before I make up my mind...
Thanks everyone so far, anyone else with other ideas??
Where are the acrylic folks? I'd prefer it over glass, don't like the idea..
Old 26th August 2005, 05:48 PM   #8
Hello,
my Scheu in wood is here (simply disregard the Morsiani turntable or the Schroeder tonearm spotting in the background)
Werner took this picture of my Scheu in steel base in 1997 or so:
The steel base is tear drop shaped with around 25cm diameter at the turntable end and about 10cm diameter at the tonearm end. it is about 30mm high and weighs more than 10kg. It was offered quite cheap, IIRC for 250 DEM, about 125 EUR/USD, and Mr Scheu stopped selling the steel base, when the steel workshop who actually manufactured the base, moved away.
best regards,
Hartmut
Old 26th August 2005, 06:47 PM   #9
Miniwatt's Avatar
Thanks Hartmut!
That looks great! But.... I'm still not satisfied.. You're using two layers of wood : what kind??
Earlier on I was dreaming about making a plinth somewhat like yours, a piece of mahogany or something like that of abouy 5 cm thick..
It's getting hard to make up my mind Maybe I'll just stick to my earlier plans, and when the curiosity is getting too much there's room for experiments!
Allthough my plinth is only 2 cm thick, and I never took it serious, I don't think it's that bad at this moment
Old 26th August 2005, 09:06 PM   #10
Cool Granite?
Hi miniwatt,
What about this one? I don't know who's the owner. but it shure is good looking!
Audiofanatic
Be nice to animals.
Page generated in 0.13484 seconds (80.45% PHP - 19.55% MySQL) with 10 queries
