Old 18th August 2005, 02:55 PM   #1
Jorge is offline Jorge  Brazil
Default Low noise head amp (MC)
Hello,
Here's a reincarnation of a head amp I've made for a Ortophon MC-20 in the mid 70's.
At that time I've used BF200 RF transistors.
S/N RIAA equalized shall be better than 80dB and distortion at 1mV input is about 0.1%.
Note: Nowadays I've not rebuilt the circuit - just simulated it.
Old 18th August 2005, 03:01 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Are you sure about this design? Shouldn't the transistors be in parallel?
/Per-Anders (my first name) or P-A as my friends call me
Old 18th August 2005, 04:38 PM   #3
I'm sure...
Very unusual, but it works.
For the lowest noise with a low impedance source, one has to use a high emitter current and a transistor with a low bulk and parasitc resistences.
Parallel transistors are used exactly to lower these resistences, and any feedback resistor will increase noise.
Using a large die transitor will have the same effect as palleling smaller ones. A RF one is even better (low rbb).
The series connected transistors used as diodes are the load, their exponential V/I curve will compensate the exponential V/I Vbe curve, cancelling distortion (at least most of it).
This is not true for a high impedance source.
Old 18th August 2005, 04:50 PM   #4
analog_sa's Avatar
15uF at MC levels
Old 18th August 2005, 04:56 PM   #5
Yes, as said low input impedance...
Old 18th August 2005, 05:02 PM   #6
forr is offline forr  France
forr's Avatar
JORGE
I mentioned this circuit a few weeks ago as being recently published in Electronics World. I think you told me you have used it a long time before. The circuit is fascinating as it is a very rare one with really no feedback at all and it still has low distorsion. Do you remember as it sounded ? I would be interested to know the results of your simulation.
It should be good as a mike preamp too.
~~~~~ Forr
Old 18th August 2005, 05:10 PM   #7
hello, forr
Honest, after all these yrs, and taking in consideration the amps & speakers of the time, I wouldn't give any opinion on sound quality.
A friend I regarded as having very good ears liked the Ortofon trafo better
But then the input cap was an electrolytic, who knows.
Here's the disto curve:
Old 18th August 2005, 05:11 PM   #8
And here's the noise:
Old 18th August 2005, 05:17 PM   #9
forr's Avatar
If I understand the curve well, distorsion is better than 80 dB, I think, for 1 mV input.
~~~~~~~ Forr
Old 18th August 2005, 10:26 PM   #10
Yes, in the sims distortion is -87 dB, but since this is just a simulation and there's no feedback, I wanted to play safe - too much, perhaps...
Low noise transistor and noise figure Real_Macgyver Solid State 26 31st January 2011 01:34 PM
motor types head to head for a TT p_ete2003 Analogue Source 20 11th January 2007 08:29 PM
Did I get in over my head too soon?!? janikphoto Tubes / Valves 15 6th November 2006 12:08 PM
I'm in way over my head. Richie V6 Multi-Way 9 8th January 2005 09:07 AM
Noise Problems in Car Head Unit fr0st Digital Source 0 30th September 2004 11:50 AM
Page generated in 0.12501 seconds (68.70% PHP - 31.30% MySQL) with 11 queries
