Old 31st July 2005, 07:53 AM   #1
mak is offline mak  Pakistan
Angry technics 1610mk2 turntable
Hi
my Technics 1610mk2 turntable does not activate the automatic arm return until moved well into the label area.
The start set in point was correctly adjusted from near the base of the tone arm; but as yet i have not been able to set the return arm point.
This is a bit different from the other technics turntables having a motor assisted arm a little perplexed!
all advise will be most appriciated
thanks
mak
Old 4th August 2005, 12:09 PM   #2
maxw is offline maxw  United Kingdom
maxw's Avatar
Hi Mak,
I had a look through my manual (I have the same TT) and couldn't find it mentioned. There is a feature that mutes the sound when the needle touches down or leaves the vinyl that you can adjust so it has the right timing. You could adjust that and then at least you wont get all the noise of it hitting the label.....maybe.
BTW my avatar is a photo I took of my 1600
Old 4th August 2005, 12:10 PM   #3
maxw's Avatar
Here is the diagram.
Technics SL turntable question jkeny Analogue Source 2 23rd September 2008 05:14 PM
Question about a Technics turntable nhuwar Analogue Source 3 30th July 2007 06:34 PM
Technics SL7 turntable mr.tranzistor Analogue Source 1 5th April 2005 12:09 AM
Turntable-Technics SL-DL1 cvele Parts 0 20th March 2004 04:39 AM
TEchnics SP10 MK II Turntable diyman Analogue Source 15 17th December 2001 02:28 PM
Page generated in 0.10219 seconds (62.93% PHP - 37.07% MySQL) with 11 queries
