| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#21 |
EC could you enlighten more about the mechanical resonances of cartridges.
Is generator droop caused by inductance? ie like a speaker bass filter in series? |
#22 | |
If the mechanical system has high effective mass (inertia), it will be more difficult to accelerate. Acceleration is proportional to frequency, so we have a mechanical low-pass filter. The more mass, the lower the frequency of the filter. Conversely, the coil's inductance combines with load capacitance to form a resonant circuit that causes HF lift up to the resonant frequency. With suitable values, this lift can exactly compensate for the mechanical low-pass filter. That's why load capacitance is critical - only one value exactly matches the mechanical losses.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#23 |
thanks, how do you determine values.
never heard of this anywhere before.....why is it not widely known? |
#24 | |
#25 |
If you had a test record that you believed with a a frequency sweep, you could display it on an oscilloscope at slow sweep speed, then try different values until you get the best response. Or you could just use the values the manufacturer specifies.
There's always one cat, isn't there?
#26 |
There is a disadvantage to peaking the frequency response by electrical resonance in the cartridge. If you simulate as a low pass filter you will see that at a Q of 0.5 there is no electrical overshoot and ringing on transients. At a Q of 0.707 there is just a tiny bit. at a Q of 1.0 it is quite noticable and at a Q of 2.0 it is bad. What you are doing is trading bandwidth extension for overshoot and ringing on transients.
This same problem exists in amplifiers when you try to extend the frequency response using a peaking coil. The theoretical maximum you can extend the response is by a factor of about 1.5, but you have a huge peak in the frequency response and terrible overshoot and ringing. Regards, Ray |
#27 | |
Did you ever look at the response of most moving coils? Rrrrrrrrrrrrring a ding ding! They do it without the assistance of an electrical boost, but ringing is ringing.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#28 | |
Dan |
#29 | |
OTOH, the single best square wave performances I've seen were from an optimally loaded Technics MM and a Dynavector MC. Go figure. In both cases, one could easily make out the ringing from the cutter head that made the test record. That's what we call "resolution."
| Moving Coil preamp design | paul joyce | Solid State | 162 | 26th October 2010 10:36 PM |
| Meridian 101 moving coil module | RCruz | Analogue Source | 1 | 24th April 2007 10:34 PM |
| Moving Coil cartridge experiment | bulgin | Analogue Source | 13 | 9th January 2007 07:57 PM |
| Moving coil meter: where to buy? | Thoru | Parts | 4 | 3rd January 2006 03:28 PM |
| SL10 Moving Coil Stage | johnsciolino | Pass Labs | 1 | 25th October 2004 05:05 PM |
| Page generated in 0.20045 seconds (43.04% PHP - 56.96% MySQL) with 11 queries |
